Originally posted by jawats
I did not use live view. I should do that, however. Perhaps a follow-up with live view. Also, for those of you who like the Tamron 60-300, do you often have CA issues?
I like playing with lenses and doing comparisons too, but it's not easy to dial in all the pieces to do a really bullet proof test. I'll be honest, I'm not looking for your exif, so bare with me if I'm saying things you already know or did, but these are things I picked up along the way. Due to lens front/back focus issues, always use live view and then use the magnification feature to zoom in on the area so you can really tell you got it. And you may very well find manual focus will be your friend here. Tripod obviously, and make sure that shake reduction is off and remote control shutter release with a delay. And foliage can be a real bear - stuff moves too much even with a light breeze, and motion blur may distort perceptions of sharpness. Good light and low ISO, of course, and be aware some cameras may or may not have shutter shock vibrations that typically occur in lower shutter speed ranges, e.g. 1/25- 1/200th. If you dig around, you will find quite a bit of discussion on that. Simple answer seems to be the occurrence is as much sample variations as not, for example, my K-1 II doesn't seem to have it, but others do seem to have it. And I'm always amazed at how much a lens's performance changes at different apertures. There is almost always a sharpness sweet spot. Bottom line is keep at it and have fun.
