Originally posted by MJKoski
Ya, that is what I thought. But if the stack height equals petal hood height, then just maybe? The built-in hood does not seem to be very long. It is just that I have have a huge bunch of 77mm filters including one expensive coated Infrared filter. I found a thread on dpreview forum where FA31mm was equipped with such stack AND a rubber hood on top of it but it was with APS-C camera body.
A stack as high as the highest part of the hood will severely vignette. With that tall a stack, you probably won't even have a usable image in square crop mode.
The high flat part of a petal hood blocks stray light from the upper and lower parts of the scene.
The lower side parts of the hood let in light from scene that makes up the the sides and corners of the image.
But if you want to test it, just make some black paper tubes 58 mm in diameter, photograph a blank wall and see how long a tube you can have before the vignetting becomes a problem.
