06-07-2019, 12:25 AM   #16
Dartmoor Dave's Avatar
A rectilinear 16mm on APS-C should give the same field of view as a 24mm on full frame. But my Zenitar 16mm on APS-C gives a field of view significantly wider than my 24mm on full frame and closer to my 20mm. I think of it as roughly equivalent to a 14mm rectilinear on APS-C.
The Zenitar defishes extremely well using the PT lens plugin, and I've often used mine as if it was effectively a rectilinear. But for astrophotography I expect defishing would produce a slight smearing effect on stars towards the corners, although it should work fine if you don't intend to defish.
Note: The quality of the results from defishing is very dependent on the software used for the job. The only plugin I've tried that really works for me is PT Lens.
06-07-2019, 05:48 AM   #17
Otis Memorial Pentaxian
QuoteOriginally posted by kypfer Quote
You've done your arithmetic incorrectly. On your K-5ii, with it's APSC sensor, the 14mm will be a "21mm-equivalent" and the 16mm will be a "24mm-equivalent", assuming comparison to a full-frame 35mm camera.
This is true except that the fisheye has a much wider FOV (180° diagonal on 24x36mm FF) for its focal length than a rectilinear 16mm (~ 107° diagonal on FF). The 1.5 crop factor equivalence does not work well in this case.
06-10-2019, 01:29 PM   #18
ZombieArmy's Avatar
The 14mm is great in my experience but I ended up returning mine because of decentering problems. I haven't heard of such issues with the Zenitar.
16mm vs rokinon, budget, da, database, fl, k-mount, lens, lenses, pentax, pentax lens, pentax-da, post, reviews, rokinon, slr lens, zenitar, zenitar 16mm vs
Ebay up to $50 off Rokinon 8mm or Rokinon 14mm catwalk Pentax Price Watch 7 07-19-2018 04:49 PM
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 2 06-28-2017 04:59 PM
Rokinon/Samyang 14mm or 16mm? donpjt Pentax SLR Lens Discussion 39 04-12-2016 02:22 AM
Samyang 14mm = Rokinon 14mm? steezylistic Troubleshooting and Beginner Help 9 02-13-2014 09:25 PM
For Sale - Sold: Zenitar 16mm f2.8, Rokinon 85mm f1.4 ltdstar Sold Items 7 05-18-2010 01:05 AM
All times are GMT -7. The time now is 11:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
