06-07-2019, 10:02 PM   #16
ZombieArmy's Avatar
I'd keep the tak bayonet, the others aren't interesting or significant enough to give up for the performance. People talk about flare but honestly if you need a lens for such demanding situations get the Samyang and save yourself some headache. If you want Tak Bayonet performance for a bit more money get the Pentax-A 135 f2.8 since it matches the tak bayonet in sharpness while having the coatings.
06-09-2019, 08:02 AM   #17
glasbak's Avatar
The screw mount takumar is optical the best of the three on 'full frame', the lower edge performace of the M goes unnoticed on apc-c, build quality of the screw mount is the best, the bayonet takumar the worst (mine keeps getting grease on the aperture blades, even after several cleanings).
06-09-2019, 10:00 AM   #18
QuoteOriginally posted by tonyzoc Quote
I'm surprised no one mentioned the SMC Pentax 135mm f/2.5 lens.
I am suprised, too. You can find the 135/3.5 on every fleamarket for cameras and it is bad! The 135/2.5 is more seldom, but MUCH better. I use it often on my K1 and I think it is in the same class than the 85/1.8.
You should buy one if you find it in good condition.
Olaf
06-09-2019, 02:11 PM   #19
GUB
GUB's Avatar
Individual lens variation would more than make up the IQ difference between these three. You need to do a test comparison on your three.
My M135 3.5 is easily the worst and my Tak Bayonet 135 2.5 is the best.
Obviously the 2.5 is a more versatile lens if you wish to utilise it wide open.
I don't notice any significant difference in the coatings.
135mm, bayonet, construction, f2.5, k-mount, lens, lenses, light, m42, metal, mm, pentax lens, pentax-m, slr lens, smc, tak, takumar, telephoto
Which one to keep? smc pentax-m 1.4 50mm, smc pentax-m 1.7 50mm or tsmc Tak f2 55mm thisisforlife Pentax SLR Lens Discussion 39 06-10-2019 01:37 PM
SMC Takumar f3.5 135mm or the SMC Pentax f3.5 135mm - Which to keep? Martinhind Pentax SLR Lens Discussion 8 04-04-2019 08:37 AM
If you could keep only one, which one and why? Ketsuppi11 Pentax SLR Lens Discussion 9 12-14-2017 10:57 AM
28mm f3.5 Super Takumar, Which one to keep Crazy Fedya Pentax SLR Lens Discussion 28 07-22-2010 10:19 PM
Ooops, won 2 135mm m42 lens, which one should I keep? reknelb Pentax SLR Lens Discussion 2 02-25-2007 11:12 AM
All times are GMT -7. The time now is 08:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
