I was able to get some beads but cutting or filing them in half turned out to be easier said then done. After telling my wife about this she told me half beads were available and are used in crafts to be glued down...perfect. so the 3mm was too small...the 5mm too big. I now have 400 4mm half beads coming that I got from China for 99 cents shipped. Anyone need any
---------- Post added 06-30-19 at 06:37 PM ----------
Originally posted by bassek Beware!
There is a hole under the nub on some lenses. Put a piece of sticker on the hole before adding glue and new bead to avoid having glue inside lens...
Seb
Good idea...I had this though as I was worried about epoxy getting into the hole and sticking to the barrel beneath...so I'm sliding a piece of thin plastic under the edge and pull it out after drying...assuming I have access ...else as you said.
