Originally posted by stevebrot Did you notice @Luftluss stuff a few posts above?
Yes, I've read all comments / posts, looked at the exif info.
In the meantime I've tried again my closeup lens on the D-FA 70-200, then found some adapter rings for the D-FA 28-105, works well on the D-FA28-105 @ 105. On the 70-200 the working distance is larger but the range of camera-subject distance for focusing is narrow and DoF is so thin. Made an experiment with a coin as subject , used the Pentax commander program, captured about 30 exposure with pixel shift and stacked them with helicon focus, the result is amazing. So the primary problem with the close up lens and 200mm isn't primarily a sharpness problem it is that the depth of field on FF + closeup lens is hardly usable with a single exposure. Getting an old MF lens is actually a cost effective option, the KIRON 105 seems pretty good and it has an aperture ring, can be used with cheap extension tubes.
