Well after post number 12 I had to get to the bottom of telephoto vs long lens. If you don't care stop reading.
As usual, after much web diving and sorting through the muck finding a few gold nuggets, I came across Rogers blog. First he describes my position. "Well, you know me, there were wrong ideas in the photography world, and I couldn’t let that alone. Wrongness must be corrected immediately! Especially wrongness that is of no importance or consequence. "
Then he gets to my findings. "Most people don’t really know what a telephoto lens is. It’s not just a lens with a long focal length (although almost all telephoto lenses do have a long focal length). But if you ask most photographers they will pick a focal length and say anything greater than 50mm or 85mm or 100mm is a telephoto lens.
If you ask more experienced photographers, they will likely say a telephoto lens has an angle of view of 35 to 10 degrees, and that lenses with less than 10 degrees angle of view are considered supertelephoto. This is more accurate, since it eliminates the variation caused by sensor size or camera format, but still not completely correct.
But if you ask a lens designer, they will tell you the actual definition of a telephoto lens is a lens with a physical length shorter than its focal length. So, for example, a Canon 100 f2.8 lens is not a telephoto (being 109mm long), while the Canon 100mm f2.0 lens is a telephoto (being 73mm long). The fact is, of course, that longer focal length lenses are more likely to be of the telephoto design simply because they’d become unwieldy if they weren’t."
Lens Rentals | Blog
Another great site
Photography | Revolvy
