Originally posted by BWG On a K-5 get the DA-40. At f/2.8 it’s better than the 43 at that aperture and it’s so much fun to use. The colors are wonderful.
don't forget the option presented by the " best lens in its class "
the SMC Pentax-DA 40mm F2.8 XS:
The SMC Pentax DA 40mm XS is based on the optical design of the SMC Pentax DA 40mm Limited, but its exterior is designed by Marc Newson so as to match the design of the K-01 mirrorless camera. The lens will work with Pentax DSLRs as well as with the K-01.
It is smaller being only 9.2 mm thick. The aperture blades are rounded which produces a smooth bokeh. The front element has SP coating which repels dust, water and grease and which makes it easier to wipe the front element clean. "
Unofficial Full-Frame Compatibility Tests by Pentax Forums
★★☆ Full coverage at some F-stop and focal length combinations
Read more at:
https://www.pentaxforums.com/lensreviews/smc-pentax-da-40mm-f2.8-xs.html#ixzz5t4yJhcwg
be sure to check out this " In Depth Review ":
Pentax DA 35mm F2.4 vs 40mm XS vs 40mm Limited
Read more at:
Pentax DA 35mm F2.4 vs 40mm XS vs 40mm Limited Review - Introduction | PentaxForums.com Reviews
