10-10-2008, 01:37 PM   #1
rfortson's Avatar
1.7x AFA and min aperture question
I had a question about the Pentax 1.7x AFA and couldn't definitively answer it, so I pose it here.
I know the AFA requireds a maximum aperture of f/4.5 or larger to work. However, I'm pretty sure you can still set your aperture to f/8 or smaller, and the AFA will still work. How does this work? Any comments/explanations?
Thanks,
Russ
10-10-2008, 02:44 PM   #2
deejjjaaaa's Avatar
QuoteOriginally posted by rfortson Quote
Thanks,
Russ
if there will be enough light... manufacturers typically say that min max resulting aperture for AF system should be 5.6, but look at Bigma - it works if light is good @ 500mm...
10-12-2008, 03:54 AM   #3
tomtor's Avatar
Thanks,
Russ
The only thing that matters is the aperture wide open, because the camera focusses wide open. So it is unimportant which aperture you select.
1.7x, 1.7x afa, afa, aperture, k-mount, pentax lens, question, slr lens
Aperture 3 topaz dNoise question Tony3d Digital Processing, Software, and Printing 3 10-20-2010 09:16 AM
operating manual cd fungerar ej i min dator men i min kompi stöpplare Troubleshooting and Beginner Help 3 08-11-2010 05:16 PM
Aperture for Portraits question MSM Photographic Technique 14 08-30-2009 01:55 AM
Question about aperture blades on my fa 31 ltd skawi Pentax SLR Lens Discussion 6 07-15-2008 01:25 PM
Question aout the aperture stops. DeoLupin Pentax SLR Lens Discussion 4 01-30-2008 06:49 AM
All times are GMT -7. The time now is 07:44 PM. | See also: NikonForums.com, part of our network of photo forums!
