Originally posted by ZombieArmy
And I'm telling you there's KAF2 mount cameras that are extremely compatible with modern and legacy lenses like the MZ-S. All cameras have KAF2 mounts to this day, otherwise you couldn't use screwdrive lenses.
The only differences that KAF3 and 4 introduced were that KAF 3 was SDM/DC only and that KAF 4 introduced the electromagnetic aperture diaphragm.
The only reason cameras like the MZ-S aren't fully compatible with basically every lens (except the 55-300 PLM) is because they lack the SDM/DC contacts. That's it. There's no inherent reason modern cameras couldn't be "un-crippled".
And you're a Pentax engineer and can say this definitively
"The Pentax mount can be 'uncrippled' for $100 or less with little R&D cost and would sell enough to recuperate the R&D cost."
Especially since, if you're in a hurry, you don't use MF glass. If you are using screw mount lenses, you clearly have time to burn. Right tool for the job and all that.
What is your expertise in this field. Have you any practical knowledge what goes into the design of a modern camera?
Your whole theory is rampant speculation by an unqualified person in a field that requires very specialized training and experience.
Personally I'd be embarrassed to trot out such speculation. I know I'm not qualified to make such judgements. But I have worked as a plant manager in furniture making and even in the plants I've worked in, making even the most basic changes can be demanding, time consuming and costly and can require the purchase of new equipment and a redesign of the production line. I seriously doubt they'd be cheaper in the camera business.
What is with your unqualified insistence that adding screw mount functionality wouldn't mean a total redesign? They could use existing components for much of it, but that's no different than what they do now when they put out a new model.
What is it that makes you say this could be easily done? Nikon doesn't fully support lenses made before 1977 so toss that speculation. Exactly who has done this easy to do, not costly thing?
Your assumption that there would be room for everything needed in the current K-1 or KP case is just bizarre. Unsupported by any real world knowledge of such things.
Of course having said that, Pentax will come out with exactly what you want in their 100th anniversary model for and extra $50. The difference between my statements and yours being, I understand how little I know and don't make wild claims based on what I think should be true, based on next to nothing.
To me, uncripppling the mount to accommodate screw mount, would be a losing proposition. Much larger companies aren't doing it, and just by the economy of scale, if it's a losing proposition for them, it would be a disaster for Pentax. Expanding KAF4 makes a lot more sense.
Maybe buy some "modern" glass, like something made in the 80s.
