Originally posted by biz-engineer Looks like the 15-30 is the wrong choice for the range of distances in that scene. The 85mm works better for that composition.
As we parked and I pulled out the camera, I had the 15-30 on because we had originally gone up there to try to shoot the Milky Way, and I wanted to get some shots of the areas that we were considering. At this location, it was just the wrong lens. The 85 was a much better selection.
Originally posted by Pentax Syntax Nice comparison. The 15-30 shot lacks foreground interest so the the telephoto shot seems a better choice for the scene. The stitched image has a different exposure/color balance so hard to compare. The clouds present a real challenge for stitching unless stationary. A substantial percentage of my landscapes are shot with a telephoto.
There was no foreground interest at this point. Everything was in the difference and you needed the focal length to shoot over the near stuff and get the far view.
Originally posted by normhead The images are three different perspectives.
What are we showing here?
That I made a stupid lens selection for the shot, and that I had forgotten just how good the old Contex was.....
Originally posted by Sandy Hancock I would have said they are all, by definition, exactly the same perspective because they were taken from the same spot. What has changed is lighting and angle of view.
For mine, the tighter angle of the single frame with the 85mm lens is the most compelling image, for the reasons already mentioned.
Yes, the same location with the lighting and the AoV difference in the lenses. Cropping the wide angle and just happening to stitch the 85 provided pretty much the same view.
Originally posted by normhead But in the larger context what does that mean? Beyond that 85mm was the most appropriate FoV from that perspective (given a choice between 15-30 and 85mm), disregarding the possibility that with a 70-200 zoom (or even a 28-105), a different FoV would likely have been the best.
Sorry if I confused you. My terminology was imprecise. Hopefully this helps.
.... and I had not shot with it for quite a while and I was really happy with the results, as the post below captures it very well.
Originally posted by TwoUptons I got two things out of the OP’s comments:
“Hey, my antique 85mm is still a pretty good lens, even compared with a brand new one”
“There is something creatively interesting about this comparison I would like to investigate and use in the future”
And then there were some nice pictures that are really tiny on my phone
-Eric
Yup!
Originally posted by joergens.mi I didn't see any advantages of stitched Panorama except for the resolution. The differences to the 30 mm shot could be egalized in photoshop.
For me the 30 mm shot feels crispier. But without a look at the photos in original resolutions you can't decide it. I like the singe 85mm shot.
I might just spend a bit more time with these and see what the results produce.
