Show Printable Version 6 Likes Search this Thread
08-05-2019, 12:35 PM   #1
doc_taz_nj's Avatar
About my Tamron 28-200 lens
I'm not sure which version I have, other than it's got a 72mm filter ring. It does have the A setting in the aperture ring. Note the reading from the RawTherapee screenshot. Samsung/Schneider... so this is a Kreuznach design? Does anyone know when this version was released?
ILCE-6300  Photo
ILCE-6300  Photo
08-05-2019, 12:39 PM   #2
Seeker of Knowledge
aslyfox's Avatar
could it be one of these ?
https://www.pentaxforums.com/userreviews/tamron-af-28-200mm-f-3-8-5-6-xr-di-...-if-macro.html
08-05-2019, 12:52 PM - 1 Like   #3
UMC
UMC's Avatar
QuoteOriginally posted by doc_taz_nj Quote
I'm not sure which version I have ... Does anyone know when this version was released?
The lens is a pure Tamron design, my guess is that RawTherapee misinterpretes the lens ID. Your lens is a Tamron Model 71D (Tamron AF Aspherical 28-200mm 1:3.8-5.6), released in 1992, see: TAMRON All-in-One Zoom Lens
Addendum: Long time ago I posted a list of Tamron 28-200 versions for Pentax in this thread: https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/330279-sho...ml#post3779622
Addendum 2:
I regard it as a mistake in PFs lens review database to mix up all the versions. In the first link I posted Tamron describes how different these lenses are....
08-05-2019, 01:14 PM - 1 Like   #4
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by UMC Quote
. . . I regard it as a mistake in PFs lens review database to mix up all the versions. In the first link I posted Tamron describes how different these lenses are....
thanks for the correction
08-05-2019, 01:31 PM - 1 Like   #5
Otis Memorial Pentaxian
Nope, it means that it returns a lens id code that RawTherapy interprets as belonging to the Samsung/Schneider D-XENON 50-200/4.0-5.6 lens*. Why that might be is anyone's guess. FWIW, the D-Xenon 50-200 is a relabeled Pentax DA 50-200 and not a Kreuznach design either.
Tamron made several versions of the 28-200/3.8-5.6. I bought a similar one for my daughter in 2007 and it is a decent performer, if a little bulky.
* It is not unusual for third-party lenses to return the same lens codes as lenses by other makers, though in this case, I suspect an error in the RawTherapee look-up table.
08-05-2019, 01:55 PM   #6
doc_taz_nj's Avatar
Ah, thanks for the point about it being mislabeled. That did seem sketchy to me.
1992, wow! I scored my copy for $32 via a Japanese seller on eBay. I'm just glad it works with all four of my Pentax bodies. Not as good at close focus as my Tamron 18-200, but I'm fine with it running at the equivalent 42-300 range for the K-x and K-70.
08-05-2019, 02:47 PM - 1 Like   #7
I wonder how well related these "modern" fixed-mount lenses are to the Adaptall-2 originals. I had one of the #71A's when they were new (mid to late '80's, at a guess) and replaced it with a #171A when they became available. The first was a vari-focal design, in that the focus changed as the lens was zoomed, and it only had a minimum focus of about 6ft, as I remember. The later lens was (is) far more user-friendly, which stayed in focus as you zoomed and with a minimum focus of 3ft. The first had a rotating front element, so the lens hood was fairly minimal, but the later had a "petal" hood which was far more efficient. My example unfortunately developed haze/fungus deep in the internals and was retired only a couple of years ago
08-05-2019, 11:31 PM   #8
UMC
UMC's Avatar
QuoteOriginally posted by kypfer Quote
According to Tamron they started developing the 28-200 in the late 80ies and the first one to appear on the market was the 71x, which was - to the best of my knowledge - the only generation, that appeared as Adpatall-2 (71A) and fixed mount (71D).
.... and replaced it with a #171A when they became available. ... with a minimum focus of 3ft. ....
That is exactly what Tamron mentions as the main advantage of the 171D in their history of 28-200s. BTW, the 171D is the technical basis of the smc Pentax-FA 1:3.8-5.6 28-200mm -IF&AL-. Actually they seem to be identical apart from the exterior "Pentax-look" and the SMC coating of course.
I once compared the optical performance of the 71D and the Pentax FA 28-200 (~Tamron 171D) and noticed a slight advantage of the Pentax. However, today on the K-1 it is simply not good enough to provide satisfactory results.
08-07-2019, 12:11 AM   #9
Not quite! The 171A was Adaptall-2 as well. I've still got my fungus-ridden example and approached Tamron UK about getting it cleaned a few years ago when it finally got too bad to use, but it was "a service they can no longer supply!". They were also "unable" to provide strip-down instructions, which was a bit of a *bleep*, but probably understandable!
08-07-2019, 12:37 AM   #10
UMC
UMC's Avatar
... The 171A was Adaptall-2 as well ....
Thank you very much for this information. The 171A seems to be a very rare beast. I've been collecting pictures of K-Mount lenses since 2012 and thus came across some 5000(!) different lenses and variants of lenses, but I've never seen the 171A. I would be more than happy if you could send me some pictures of the lens (either PM or post it in this thread).
08-07-2019, 04:06 AM - 1 Like   #11
Herewith the Tamron Adaptall-2 #171A 28-200mm lens attached to my K-70 (and photographed with my *ist DL2)
Hope this helps
PENTAX *ist DL2  Photo
08-07-2019, 12:16 PM - 1 Like   #12
UMC
UMC's Avatar
Now that we have hijacked this thread, I have to thank you for posting this picture. Surprisingly the 171A does not look like the 171D at all, but rather like the much later 371D.
08-07-2019, 02:00 PM   #13
doc_taz_nj's Avatar
No worries about the hijacking. I'm learning a lot from you folks.
08-07-2019, 03:20 PM   #14
boriscleto's Avatar
BTW, the 171D is the technical basis of the smc Pentax-FA 1:3.8-5.6 28-200mm -IF&AL-. .
The FA 28-200 is based on the 271D. Different optical formula...
171D 15 elements in 13 groups, 271D 16 elements in 14 groups.
08-08-2019, 11:39 AM   #15
UMC
UMC's Avatar
QuoteOriginally posted by boriscleto Quote
I would like to challenge this: According to the Japanese Tamron site (171D and 271D) 171D and 271D are identical apart from the exterior appearance. They are both listed as 16 elements in 14 groups with a minimal focusing distance of 0.52 m. These are exactly the same specifications that Pentax lists in their 1998 edition of the "smc Pentax-FA interchangeable lenses" manual.
The later model 371D is also similar but has a slightly better focusing distance of 0.49m.
k-mount, pentax lens, ring, slr lens, version
For Sale - Sold: Full frame AF and MF 'A' lenses - 17-35, 18-35, 24-70, 28, 28-105, 28-200, 135,70-210 scottDee Sold Items 9 02-13-2019 06:57 AM
For Sale - Sold: K/M/A 3rd Party Zenitar 16, Vivitar 24/2, 200, 28-80, 35-70, 28-210, 80-200, adapters MightyMike Sold Items 63 12-29-2018 08:44 AM
For Sale - Sold: K10D+grip, DA12-24mm,14mm 2.8, 75-200 f3.8, 28-200, 70-300, 80-200 f4.7-5.6 igowerf Sold Items 2 02-07-2018 08:33 PM
All times are GMT -7. The time now is 08:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
