I've just recently taken my 35/2.3 apart and re-lubed the aperture clicker. You don't need to go in from the front, it's really pretty easy. In the link that c.a.m. pointed out, go to step 4. Then remove the screw shown by the green arrow in step 7, and that holds in the spring that holds the small cylindrical bearing that clicks the aperture. Remove that screw slowly so the spring doesn't go springy on you.
Reassemble without the screw, spring or cylinder, and you should be good to go. Reassemble and enjoy. Keep the parts in a tiny zip lock bag, and reassemble if needed to re-click the lens. This involves zero destruction, easy to reverse so those claiming you are doing something terrible to a rare lens can stick it in their ear. Have fun!
One more trick, before disassembling, set the aperture to f22. The mechanism that controls the aperture is easier to align at f22 than at f2.3.
If you have any questions, you can send me a private message, and that will ping my email to check, and I'm happy to help. It's really very easy work though.
