Originally posted by onlineflyer However on the element just below the front group there looks to be a smallish patch of dried condensation around a small section of its edge."
I requested pictures from the seller. What questions should I ask, what should I concerned with?
Thx in advance
Unless you are proficient at taking a lens apart and doing a CLA job on it, don't buy this lens.
If the defect (dried condensation) were behind either the front or the rear elements, it would be a relatively easy "do it yourself" fix. However, the seller said that this defect is below the "front group". That means it's deeper inside of the lens, which means it's probably difficult for the average photographer to get to the defect to correct.
But, if the lens is cheap enough, and you can live with the defect and are willing to gamble that it doesn't get worse you might want to buy the lens, live with the defect and hope it does not either affect your photos or get worse.
