Originally posted by brightseal Which f 2.8 macro?
100mm macro
---------- Post added 08-12-19 at 02:57 AM ----------
Originally posted by jatrax Try cleaning the contacts on both the camera and lens.
This has been tried multiple times, but thank you for the response.
---------- Post added 08-12-19 at 02:59 AM ----------
Originally posted by pschlute Select "sensor cleaning" from the menu. This will lift the mirror and expose the sensor. Use a rocket blower to knock any dust off the AF module.
The AF module is located at the bottom of the mirror box, behind the mirror. That is why you need the mirror up to use the blower.
Try the lens again.
I will try this, but I would assume that my other AF lenses wouldn't function proper if the AF module was dirty. I tried my old DA and it functions like a champ.
---------- Post added 08-12-19 at 03:01 AM ----------
Originally posted by Not a Number Does the lens have an aperture ring? Set to "A"?
No, the lens is set correctly and was working fine, then it just stopped auto focusing and continued to hunt and hunt and hunt.
---------- Post added 08-12-19 at 03:14 AM ----------
OK, I just noticed something that the lens appears to be doing. My manual focus is only working in the macro mode, I cannot focus out to infinity in manual or AF. I seem to be stuck in the macro mode and cant set the lens back to full focus. The AF is working up-close also. Any ideas on how to fix this problem?
