08-15-2019, 05:23 AM   #1
Leica lens to pk mount adapter that will focus to infinity?
Dear fellow Pentaxians,
hoping that this question will not be deemed to far off-topic, I ask you this: having started playing around with takumar m42 lenses See attached image of a plum blossom, (Pentax K-7, Takumar 50mm f1.4 and extensiontubes) and after that some third party lenses, and having seen an ad for an affordable Leica lens, the LEICA ELMARIT-R 180MM F/2.8, I would like to know what is the best, if at all available, adapter to pk-mount that will enable infinity focus. Thank you for your replies,
321pentaprism
PENTAX K-7  Photo
08-15-2019, 06:06 AM - 1 Like   #2
Fogel70's Avatar
Leica R and Pentax K have register distance that are very close.
So it is not easy to make an adapter that focus on infnity. You would basically need a teleconverter with K-mount on the camera end and Leica-R on the lens end. I do not think this type of adapter exist.
Another solution is to modify the lens with a new mount. Leica & Pentax & Nikon | Leitax
08-15-2019, 06:39 AM   #3
Otis Memorial Pentaxian
Welcome to the Pentax Forums!
As noted above, Leitax is the most effective way to adapt Leica R lenses to Pentax K. A similar problem exists for Nikon F and Pentax K where the registration distances are also quite close and where Leitax is also the preferable solution.
08-15-2019, 09:02 AM   #4
Thank you so much, Steve!
08-15-2019, 11:17 PM   #5
david94903's Avatar
I converted a Nikkor 135mm f/2.8 AI lens recently. I was my first Leitax conversion. I followed the instructions online, and it was pretty easy. Though some lenses are more difficult than others. Fenwoodian has converted a number of Leica lenses with the Leitax mounts. He could tell you a lot more about the process of converting those lenses.
08-18-2019, 10:18 AM - 1 Like   #6
QuoteOriginally posted by david94903 Quote
Yep...@Fenwoodian is the forum expert on Leitax and the man in the know.
08-20-2019, 07:40 AM   #7
Thanks a lot, Dave!
08-20-2019, 08:23 AM - 1 Like   #8
Fenwoodian's Avatar
Your LEICA ELMARIT-R 180MM F/2.8 lens is very easy to adapt (I own one and have already adapted it). An easy do-it-yourself project - all you need (besides the "classic" Leitax Leica R to Pentax K adapter) is a small philips head screw driver (magnetize it before using) and some lens grease.
Some Leica R lenses are easy to "Leitax" adapt. Some are harder. One is impossible (90mm f/2 Summicron).
08-22-2019, 07:14 AM   #9
QuoteOriginally posted by Fenwoodian Quote
Thank you Fenwoodian!
adapter, focus, k-mount, leica, leica lens, leica lens to pk adapter, lens, lens to pk, lenses, pentax lens, pk mount adapter, slr lens, takumar
Tokina RMC 80-200mm F4 PK/A mount - infinity focus adjustment for long end mlipovac Pentax SLR Lens Discussion 5 05-04-2016 11:12 PM
PK mount Makinon won't focus to infinity ChildOfVision Pentax SLR Lens Discussion 6 08-16-2009 04:58 PM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
