Originally posted by Fogel70
As I said in my post you quoted, when using same FOV, DOF and perspective on different formats FOV will obviously not be concerned as it is the same on both.
But try to repeat those things I said.
Let say you shoot same type shot with Pentax K-1 and Pentax Q (With crop factor of 5.5).
The lens used on K1 is FA 43 f/1.9 and on Q you use Prime 1 which is 8.5 mm and f/1.9. For closest match in FOV.
The shot on K1 is shot at f/11, 1/50s and ISO100.
To match DOF on K1 you need to use f/2 on Q and shutter speed has to be set at 1/1600s to avoid overexposure at ISO 100.
This is the problem with the equivalence people. Instead of talking about a single lens used on two different bodies they (you) always talk about making the FOV the same from the same spot. The only way you can get the same FOV with two different sized sensors is change the lens to match the FOV for the bodies sensor. We get that.
But:
I, for one, do not care at all about getting the same FOV from two bodies with different sized sensors because I only have APS-C cameras. Now, truth be told, I have some 35mm SLR's and I could go through all that "stuff" to get a equivalent FOV from two formats. Or, I could just take pictures using the features of each format to display different images. Why in the name of heaven would I want to replicate the images between formats? That is a colossal waste of time and effort, as a photographer I gain zip, nada, nothing, bubkis...
As for exposure? Well if I have my light meter set at ISO 400 and it says to use f/8 at 1/250 of a second......
When I expose for my APS-C camera, my film SLR (ILFORD HP5) and my 4x5 monorail (ILFORD HP5). Guess what --------- I use the same "exposure triangle" for each camera. As I said before, there is no "sensor size" setting on my Gossen Digipro F. Again, this exercise would be a colossal waste of time, effort, film/developer and disk space.
Further, if I have a object (box) that is projected on a sensor as image of
10mm high using my FA 50mm f/1.4 on a 35mm film camera and I put the same lens on my K-3II (or K10D or K20D) the box will be..... wait for it
10mm high on the sensor. In other more simple words, exactly the same size. If it is set to f/8 and the shutter is tripped at 1/125 at ISO 400 then the exact same number of photons will hit the 10mm area on the sensor of both the film (so called full frame) and the APS-C sensor. That is because the lens obeys the laws of physics. The physics of the lens is not changed because the sensor size is different.
Good Grief - get real.
