08-23-2019, 02:39 AM - 2 Likes   #181
pschlute's Avatar
QuoteOriginally posted by beholder3 Quote
The Apsc sensor is 2;25 times smaller than a FF sensor. And you print to what size?
There is a huge magnification going on with every digital photo. Or do you watch your apsc photos on a screen sized 16x24 mm?
If we take a K5/K1 in crop mode sensor as an example 16.3MP 4928x3264 pixels. My monitor is 2560x1440. In full screen view I am seeing the image at around half its actual size, not enlarged at all, let alone a huge one.
When you print an image your print size is determined by the image file pixel dimensions and the ppi. At say 300 ppi You could print that image at 16"x10.88". No enlargement required. No magnification
The point is that pixels in an image file do not have a physical size.
08-23-2019, 02:45 AM - 1 Like   #182
QuoteOriginally posted by GUB Quote
It would be quite cool to have a monitor at 7372:4924 resolution. But I don't think we are there yet even with large screen tvs are we?
Pixel count or size have no relevancy in this discussion at all unless someone declares it is only about different photo end results sizes. So far the thread opener has not made this statement.
So for the time being I can only advise any reader to flat out ignore every single post mentioning pixel size or pixel count here in this thread about light gathering of lenses.
---------- Post added 23rd Aug 2019 at 11:51 ----------
When you print an image your print size is determined by the image file pixel size and the ppi. At say 300 ppi You could print that image at 16"x10.88". No enlargement required. No magnification
I was talking about size in millimeters.
I do hope you do understand that taking the image of a 16x24mm apsc sensor and printing it to your 16x10 inches involves a LOT of magnification. And less so if the image had been from a large format film camera.
08-23-2019, 02:53 AM - 2 Likes   #183
pschlute's Avatar
Ahem...point of order Sir...
It was you that brought pixel size into the discussion by claiming that every digital image required "huge magnification".
08-23-2019, 03:06 AM - 1 Like   #184
GUB
GUB's Avatar
That was a bit silly considering you were responding to a statement about resolution.
08-23-2019, 03:11 AM - 1 Like   #185
pschlute's Avatar
I hope you understand that a pixel has no physical size.
08-23-2019, 03:21 AM - 1 Like   #186
Dartmoor Dave's Avatar
Please think very carefully about the important point that pschlute has stated far better and far more succinctly than I've done: Pixels in an image file do not have a physical size.
Now this next bit is going to blow your mind: a 16"x10.88" print from a 16 megapixel file is effectively a contact print. It's a print at 1:1 resolution, in which one pixel on the sensor equals one dot of ink on the print (told you it would blow your mind).
It can seem counterintuitive, which is why so many people prefer the comforting myths of equivalence, but when we're talking about digital photography the physical size of sensors and screens usually has very little to do with things. After all, your computer doesn't need to know the physical size of your monitor to display photos properly, does it? All it needs to know is the pixel resolution
08-23-2019, 03:22 AM - 1 Like   #187
Is this a joke? Magnification is the difference between input / sensor and output size. Pixels are nowhere part of the equation.
---------- Post added 23rd Aug 2019 at 12:24 ----------
Again: Pixels are not relevant. And: pixels on the sensor do have a size.
08-23-2019, 03:28 AM - 2 Likes   #188
GUB
GUB's Avatar
When I set my editor image to 100% it matches the image pixel to the screen pixel so you are simply wrong
08-23-2019, 03:29 AM - 2 Likes   #189
Oookaaaayyyy. . . .
Um. . . .
So maybe a digital sensor is full of microscopic elves painting oil paintings very quickly?
08-23-2019, 03:31 AM - 1 Like   #190
GUB
GUB's Avatar
QuoteOriginally posted by Dartmoor Dave Quote
Oookaaaayyyy. . . .
Um. . . .
OK, you are back on the Dartmoor mushrooms aren't you!
08-23-2019, 03:34 AM - 3 Likes   #191
This thread is making me feel that way. And the problem is, from now on I'm only ever going to be able to talk about resolution in terms of micro-elves.
08-23-2019, 04:12 AM   #192
Oookaaaayyyy. . . .
Um. . . .
As in Discworld?
08-23-2019, 04:14 AM - 1 Like   #193
It has now been stated by everyone, pixels are not used to measure size. Right, keep that in mind for the rest of this post. Pixels are not ….
So take for example an image projected on a 35mm frame/sensor and then viewed on a 24” screen.
Has the image size been reduced? (Remember, pixels are NOT a measurement of size, millimeter are.)
It has been enlarged.
If we now take an image from a APS-C sensor and display it on the same 24” screen, it has to be enlarged even more then the FF image to fill the screen. ENLARGED, even though it was down sampled. Pixels are NOT used to measure size.
08-23-2019, 04:53 AM   #194
swanlefitte's Avatar
That is a real equivalence.
A monitor with one pixel will display one pixel or down sample or up sample. But it is 1 pixel. How can you say that huge pixel vs a camera pixel is magnification of the sensor?
One pixel is equivalent to one pixel. I guess you can say the pixel is magnified but that has no real meaning.
08-23-2019, 04:55 AM - 1 Like   #195
GUB
GUB's Avatar
QuoteOriginally posted by Gimbal Quote
So when my image viewer magnification is set to 100% it should show the image at the size of the sensor according to that.
50mm, amount, aps-c, bokeh, camera, distance, energy, exposure, ff, image, iris, iso, jpg, k-mount, lens, light, metal, paint, pentax lens, pixel, print, sensor, shutter, size, slr lens, unit, water
Thought FF (k1) would give me. Significant increase in light gathering vs k70 Mazzoman Pentax Full Frame 31 12-10-2017 12:57 AM
FF vs APS-C light gathering / noise CypherOz General Photography 21 06-13-2014 10:25 AM
60-250/50-135 macro abilities jenst Pentax SLR Lens Discussion 3 05-13-2014 06:22 PM
A Realization on my Abilities interested_observer Pentax SLR Lens Discussion 19 04-22-2014 09:04 PM
Is there unit for light gathering properties of a lens? Reportage Pentax SLR Lens Discussion 9 03-12-2012 07:37 AM
All times are GMT -7. The time now is 08:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
