Originally posted by Photobill
I should know, but I don't.
When people talk of the deference between FF & APS-C regarding the f-stop they mostly cover the bokeh.
My question is:
When using my SMC Pentax 55mm F1.8 @ 1.8 on a APS-C camera does that sensor get approximately the same amount of light as using it on a FF @ the same f:stop? There is a lot of talk about loosing almost a full f: when using lenses on crop body's but can you please clarify if this is mostly about the bokeh or does it also play a part in exposure?
Sample
I use a light meter and it says shoot the scene @ f2.4 Would I get approximately the same expo with a FF & APS-C body? Or would I need to open up to f:2 or f:1.8 on the APS-C to get the equivalent exposure as on a FF.
As I said I should know this, but I do not 😞
Thanks to anyone that can set me straight. 🙌
The key to understanding is the concept of „magnification“.
If you compare a roughly half area (of FF) apsc sensor to FF using images displayed same size on a screen then the apsc has been magnified twice as much.
Exposure parameters on the other side only defines how much light hits a specific same area of the sensor. Obviously if you set 1/100 second F2 ISO 100 one square centimeter of sensor of both a small and a big sensor get the same amount of light, generating the same „brightness“ in the image - and its not getting darker just because your print is magnified more or less.
That is mostly due to the fact that the fnumber is a relative term ignoring the absolute image circle of a lens. An f4 large format lens and a f4 phone lens allow the same amount of light per square centimeter, even though the total (!) light gathered by the large format lens will be much much more.
So *on the sensor* per same area the results are the same.
But: The „light gathering abilities“ are usually referred to in the context of noise, dynamic range and background blur. Those three absolutely depend on magnification, not only on what happens on the sensor. If you watch your images from farther away you reduce magnification and you will see less noise for example. Even if on pixel level on the sensor there is still the exact same amount.
