08-24-2019, 10:13 AM   #1
Pentax 18-270 DA - Zoom Lock fault
Hi,
I've been using a Pentax DA 18-250mm f/3.5-6.3 Lens for a couple of years and been really pleased with it. Clearly it's not a top-end lens but for my budget it has proved excellent and a really versatile workhorse that I rarely take off the camera.
One of its features is a "zoom lock", designed to lock the zoom mechanism at the 18mm position when the camera/lens isn't being used.
Whilst away on holiday recently the lens has become locked "permanently" at the 18mm position even when the zoom lock itself it "off", so the lens cannot now be zoomed at all.
Has anyone else experienced this and if so do they have any hints for addressing the issue? Is it worth trying to get repaired or is the cost likely to be about the same as buying a new lens? Any other recommendations?
Any advice would be gratefully received.
Thanks
08-24-2019, 11:17 AM - 1 Like   #2
Not a Number's Avatar
I don't have that lens so I don't have any useful advice on a workaround.
Precision Camera quotes $262.50 USD to fix that lens which is around half of what a new one would cost in the US.
08-24-2019, 06:01 PM - 1 Like   #3
Is your lens the 18-250 or 18-270 (title says 270 but post mentions 250)?
What I do know is that the 18-250 can get stuck at 18mm when an internal part gets loose: there's a small screw which is accessible via a hole in the zoom barrel under the rubber grip. If the screw loosens it can protrude into this hole and lock up the lens.This makes the lens feel like the zoom lock is applied even when said zoom lock switch is working normally.
My advice would be to peel back the rubber grip, inspect any access holes and make sure any visible screws are nipped up tight. If you're lucky this will solve the problem.
Edited to add: seems I'm not the only one to have fixed this problem. A quick search found a post here describing a similar problem and detailing the repair steps: the offending screw and collar can clearly be seen in the pic: http://usefulbulk.com/pentaxlens/
08-25-2019, 08:55 AM   #4
Hi Suzhouren,
Apologies, the lens is the 18-250 (I corrected the post but forgot to edit the title )
Anyway - I am very much obliged to you, your advice proved to be 100% spot-on: I found the screw under the rubber grip and it had come loose - tightened it up accordingly and all is now good.
Many thanks!
Mike
18mm, da, k-mount, lens, pentax, pentax 18-270 da, pentax lens, position, slr lens
Superzoom lenses (18-250, 18-270, 18-300, 28-300), show us what they can do madbrain Pentax SLR Lens Discussion 3 06-30-2018 06:14 AM
Universal Pentax zoom tele lense...which one? 18-270 vs 55-300 dark64 Pentax DSLR Discussion 17 12-18-2016 01:39 PM
For Sale - Sold: HD DA 35/2.8 Ltd. & DA 18-270 zoom dshombert Sold Items 5 01-02-2016 06:22 AM
Availability of the Pentax DA 18-270 Zoom?? Jatcat Ask B&H Photo! 3 12-19-2012 01:01 PM
Pentax 18-55 + 50-200 vs. Pentax 18-135 wr vs. Tamron 18-270 Italian Pentax SLR Lens Discussion 2 11-28-2010 03:33 AM
All times are GMT -7. The time now is 11:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
