09-20-2019, 02:01 PM   #1
Frito's Avatar
Lens advice
Hey Guys
I have a ME Super with a 50mm f/1.7 on it. would like some advice for a good wide angle and telephoto lens at a reasonable price.
( if there is such a thing ) I like to be able to take pics of wildlife and people. Thank you for any advice
FRITO
09-20-2019, 02:12 PM   #2
I have the Pentax 16-85 (AF) lens. It takes really nice images.
09-20-2019, 02:20 PM   #3
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by Frito Quote
ME Super
I'd probably go for a Pentax M 200mm f/4 for wildlife - https://www.pentaxforums.com/lensreviews/SMC-Pentax-M-200mm-F4-Lens.html
I'd probably go for a Pentax M 28mm f/2.8 for wide angle - https://www.pentaxforums.com/lensreviews/SMC-Pentax-M-28mm-F2.8-Lens.html
Best luck!
09-20-2019, 02:32 PM   #4
ismaelg's Avatar
Hello,
For telephoto, If I can suggest a zoom: the A-70-210 f4 is very good and very affordable.
Thanks,
Ismael
09-20-2019, 02:37 PM   #5
For 28mm have a browse through the 28mm lens club thread:
DSLR fun with 28mm: Club for any 28mm lens - PentaxForums.com
There's plenty of choice of good ones: tokina, sigma, vivitar... out of the pentax line up I would suggest the smc-m f3.5, almost a good as the vaunted "K" 28mm f3.5 but much cheaper and more readily found.
For wildife, IMO 200mm is too short. There is a gap in the pentax line up at 300mm f5.6. The 300mm f4 star's are good but pricy, as are the 400mm options. I suggest a tamron adaptall 300mm f5.6 - the version 1 is best value. At 400mm I suggest look for a tokina 400mm f5.6 or f6.3. The more modern f5.6's are more compact and have closer focus but IMO don'thave any iq advantage. Tokina primes. NB the sigma apo 400mm f5.6 is optically far superior in design but I have yet to find one that doesn't suffer from balsam separation/deterioration of a group in the middle of the lens. The non-apo sigma 400mm f5.6 MC is quite good, similar iq to the tokinas but worse (terrible) fringing.
09-20-2019, 05:53 PM   #6
UncleVanya's Avatar
QuoteOriginally posted by C_Jones Quote
That's an apsc lens and won't cover the film frame fully. It will also not be very easy to focus manually as it has a moderately slow max aperture that may darken the viewfinder focusing aids.
---------- Post added 09-20-19 at 08:55 PM ----------
How wide, how long? Handheld only or tripod? Wildlife from a blind or stalked?
09-20-2019, 09:45 PM   #7
ChristianRock's Avatar
I agree with the SMC-A 70-210mm f4 suggestion. The SMC-M 75-150mm is also a wonderful lens.
With wide, there are a few 24mm f2.8lenses out there, most are very good. Or one of the SMC Pentax 28mm f3.5 lenses (there was a K and an M version), those are particularly good.
09-21-2019, 12:23 AM   #8
Chris_K's Avatar
Hey Guys
FRITO
As a wide-angle, M-28 will work very well. The one with f/3.5 seems to be better than f/2.8 (which is still ok!). As a telephoto, M-200/4 should be fine and affordable. Having those two and playing with them for a while will tell you if and what else do you need. M-135 will be good for portraits (200 mm might be too narrow for that).
09-21-2019, 07:09 AM   #9
Frito's Avatar
Thank you all for the suggestions, these were all the ones I was hopeing for. I will def look into all of them. Once again thank you for your help.
Frito
09-21-2019, 10:57 AM   #10
The Tokina AF 19-35mm f/3.5-4.5 zoom lens can produce very fine results also. It is well-made yet inexpensive. It has the flexibility of being a zoom lens for framing your shot from a given position, being able to vary the degree of wide angle. It is an autofocus lens (AF), but can be used with the MF ME Super with no problem, since it is equipped with an aperture ring.
09-21-2019, 08:28 PM - 1 Like   #11
QuoteOriginally posted by FozzFoster Quote
I'd probably go for a Pentax M 200mm f/4 for wildlife - SMC Pentax-M 200mm F4 Reviews - M Prime Lenses - Pentax Lens Reviews & Lens Database
I'd probably go for a Pentax M 28mm f/2.8 for wide angle - SMC Pentax-M 28mm F2.8 Reviews - M Prime Lenses - Pentax Lens Reviews & Lens Database
Best luck!
I second these two suggestions.
Both good image quality, well made, compact and very affordable.
09-23-2019, 04:43 AM   #12
I used a ME Super for years for wildlife, and the 200mm was rarely long enough. the M-200mm/f4 with a teleconverter would be a good reach, but really slows down your shutter.
I used a 500mm mirror lens for a long time, the Tokina 500mm/f8. More recently I have acquired a Tamron 500mm/f8 which is noticeably heavier but is quite sharp. These are both easy to find for about $100, and the Tamron often is sold with the matched teleconverter. I found the 500mm mirror lens easier to hold than the 200mm with a teleconverter.
The M lenses were meant for the ME Super, I would suggest looking for the M28mm/f3.5 and the M-Zoom 80-200mm, then chasing a Tamorn mirror lens with a PJK adapter (the miroor lens is fixed aperture so you do not need the Tamron PK-A adapter ring.
09-23-2019, 05:03 AM   #13
Seeker of Knowledge
aslyfox's Avatar
Hey Guys
FRITO
here is a link to the user reviews of the ME Super:
it's description:
The Pentax ME Super improved upon the original ME by introducing two push buttons on the top plate allowing the user to electronically dial in the desired shutter speed, giving him or her much more flexibility when shooting manually. This design was later carried over to the ME F (Pentax's first autofocus camera) and the Super A (which could set the aperture automatically and hence provided Tv and Program automation in addition to the Av and M exposure modes of the ME Super).
Other improvements over the ME was a faster top shutter speed of 1/2000 s and a warning light in the view finder when EV compensation was engaged.
Variants:
PENTAX ME Super: The original
PENTAX ME Super SE: A 'Special Edition' version was released in later years, featuring a diagonal split screen rather than a horizontal one
Read more at: https://www.pentaxforums.com/camerareviews/pentax-me-super.html#ixzz60LgYsxix
_________________
as far as lenses
I might be tempted to look at some of the Vivitar Series 1 lenses
Vivitar Lenses - Pentax Lens Review Database
______________________________________
this chart might be helpful:
https://www.mosphotos.com/PentaxLensCompatibility.html
09-23-2019, 05:43 AM - 3 Likes   #14
Sandy Hancock's Avatar
Nice try. That lens will be completely unusable on an ME Super. The image circle is too small, no aperture control is possible, and AF is of course wasted.
To the OP: for wide angle, the K28/3.5 and K20/4.0 are highly regarded.
In the wildlife range, the K200/4.0 looks like excellent value for money if you can find one.
You need to define "reasonable price" for your needs. I have the K28/2.0 and K200/2.5, but they are pretty pricey.
advice, k-mount, lens, pentax lens, slr lens
Lens advice Safari Botswana, Namibia, South Africa. What range is most useful? -JW- Pentax SLR Lens Discussion 69 01-04-2020 08:02 AM
Weird cast to lens - any advice ? Astro-Baby Pentax SLR Lens Discussion 9 05-10-2019 10:44 AM
Lens Repair Advice/Help - Sigma Mini Zoom 39-80 Astro-Baby Pentax SLR Lens Discussion 6 02-24-2019 10:59 AM
Lens Advice for a Landscape Focused DSLR Beginner catwalk Troubleshooting and Beginner Help 21 07-07-2018 12:13 AM
Advice Columnist Advice on Photography - do you agree? betsypdx General Talk 9 06-24-2007 12:45 PM
All times are GMT -7. The time now is 11:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
