Originally posted by Billy Joe Well this completely has me scared to consider Pentax full frame... I used my M42 Helios lenses on a Sony full frame and had no issues with light leakage.
How can this be a problem with a K-mount?
As @GUB says, don't be concerned.
The reason it wasn't an issue with your Sony gear is that the registration distance between sensor and mount is smaller, so the adapter for M42 is longer and can therefore sit right on top of the camera's mount. With Pentax, the K-mount registration distance is exactly the same as M42, so the adapter has to sit
inside the camera's mount - i.e. it can't protrude further than the edge of the mount (this is why adapters that cover the camera's mount won't allow infinity focus, as they're pushing the lens further forward). The slots in the Pentax M42 adapter are essential to allow fitting and removal.
It's worth noting that M42 (or any other mount) adapters for Sony come with their own set of problems - for example, lateral movement that can result in de-centered positioning, poor machining and construction that can result in tilted mounting of lenses and a plane of focus that isn't completely parallel to the sensor, internal reflections that can lead to veiling flare and strange artefacts on photos, etc. You may not have noticed these when shooting adapted lenses on Sony, but I can almost guarantee you've experienced it, even if you didn't realise. I shoot an A7 MkII with various adapters for my vintage lenses, and over time I've had all of the problems I mentioned.
Originally posted by Billy Joe Is this also going to be a problem on a KP? An issue with the adaptor/lens combo?
Yes, but it's really not a problem. Just a quirk that you need to work around, and it's easy to do. Just review that link I posted
