I recently purchased a Takumar 35mm f2.3. So far it's lived up to its reputation - beautiful colors, fantastic rendering wide open, and very sharp closed down.
As with all of these early Tak's, they don't do well shooting into the sun since they lack the SMC coatings. This lens is particularly sensitive to flairing because of the rather exposed first element.
There is a lens hood for it, but it is very rare to find one. It screws onto the outside of the lens barrel. You can't use the filter threads to put on a substitute hood because it will cause vignetting.
My solution was to design a new hood and 3D print it. There is a split collar that attaches to the barrel with a small screw. The collar makes it difficult to get that lovely lens cap off, so I put some cut-outs in the sides of the collar. The hood is a bayonet mount that is reversible. Now that precious outer element is protected by the hood, and there are less issues with flare. The only downside is that the lens doesn't fit in its original case with the collar attached. Perhaps I'll design a quick-release collar to deal with that issue. Below are some photos of it on my K-70, and mounted on its contemporary, the Asahi Pentax S. The printed plastic was a shiny black so I've painted it to be more of a matte color.
