10-08-2019, 06:14 AM   #1
Filter Options??
I have a Samyang 14mm F2.8 lens that I really like, but I 'd love to add a circular polarizer to it for some shots. Has any one found a graceful and robust way to do this?
10-08-2019, 06:44 AM   #2
QuoteOriginally posted by BillO Quote
I am sure later you will be thinking of adding variable ND. I bought and still use on my 24-70 f2.8 this one: Vivitar 72mm Series 1 Variable Range Neutral Density ND Camera Lens Filter NEW 681066621660 | eBay
It works as a polarizer and ND. Yes, it has a dark "X"at max, but if you do not go to that extreme it works fine.
You can not add lens hood with the filter.
Regards
10-08-2019, 07:01 AM   #3
pschlute's Avatar
Lee filters do an adapter ring for their 150 filter system. Not going to be cheap !! i use the Lee system for my 15-30 zoom
LEE System Match - find the recommended System for each of your lenses.
10-08-2019, 07:12 AM   #4
Unless You spend $600+ there is NO good options. Lee is probably the easiest way to go. Currently $206 just for the SW150 holder......Good Luck !
10-08-2019, 09:34 AM - 1 Like   #5
pschlute's Avatar
are you using it on FF ? i think 14 is a bit wide to get a nice PL affect
10-08-2019, 11:22 AM   #6
You could adapt a polarizer to go behind the lens. A small disc polarizer can be mounted over the rear element (I'm referencing a 13mm Vivitar here and the Samyang may be different) but the downside is that it would have to be set by trial and error since you can't rotate it to get the polarization desired, however once set, it should work. Another downside is that through a wide angle lens, the sky will be uneven since polarization differs across the sky and a wide angle lens takes all that in.
10-09-2019, 05:49 AM   #7
QuoteOriginally posted by Vasyl Quote
Regards
The lens hood is builtin the Samyang and there are no threads for a filter. A solution like this would be great, but it can't be.
---------- Post added 10-09-19 at 08:55 AM ----------
No, it is used on a K3 or K3-II so effectively its about 22mm.
filter, hood, k-mount, k3, lens, pentax lens, slr lens
Pentax DA 21mm f/3.2 AL Limited filter options rptdc Pentax SLR Lens Discussion 3 06-13-2018 11:19 AM
Options, options, K-1, 24-70 or 31 Limited. lesmore49 Pentax SLR Lens Discussion 13 03-10-2017 08:30 AM
Suggestion Add format and camera filter options to the reviews UncleVanya Site Suggestions and Help 5 05-20-2016 01:53 PM
Filter Options eccs19 Pentax Camera and Field Accessories 11 01-25-2013 11:51 PM
49mm ND filter options (around 6-stop)? scathontiphat Pentax SLR Lens Discussion 6 04-16-2011 02:27 PM
All times are GMT -7. The time now is 12:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
