Originally posted by nutz New here so I will keep it short; I have a Pentax istDs camera with the 18-55MM lens. Awhile back the pictures have all had what looks like a shadow around the corners of the pictures, I am sure it's from the lens as I have cleaned and it still is doing it. I tried a different lens and it didn't do it with it. As you can see in the pics I added it is pretty bad but funny thing is it doesn't do it on every shot.
Can anyone tell me what's going on with this lens?
Thanks
Just by chance, do you happen to also own the 50-200mm lens and have managed to swap the lens hoods?
The fitting is the same and they will mechanically interchange!
For reference, the 50-200mm hood is "PH-RBB 52mm", the hood for the 18-55mm is "PH-RBA 52mm". These are the numbers on the hoods on my lenses, I'd guess the "PH-RBC" quoted above is possibly a later version, what differences there are, if any, I don't know, but brief research suggests the "PH-RBC" is for the "WR" lens and is not interchangeable with the earlier version!
