10-17-2008, 12:52 AM   #16
The kit lens should serve you well.
I got a good deal of use out of it, but in the end it was too slow for me.
10-17-2008, 04:38 AM   #17
bdery's Avatar
For the record, I already own the Kit Lens (18-55mm) and the Sigma 17-70mm.
Then there is no possible question. Take the Sigma. And bring a fast fifty, you'll be all set.
10-17-2008, 04:54 AM   #18
geauxpez's Avatar
And an added bonus of the kit lens: though it isn't weather sealed, what you pay for a replacement on the used market makes it nearly disposable. (c:
10-17-2008, 06:22 AM   #19
mk07138's Avatar
Just to throw in my two cents, I take the 16-50 f2.8 on backpacking trips quite often. Yes it is big and heavy but its a great performer, and the weather sealing has been put to the test several times now.
10-17-2008, 07:28 AM   #20
wildboar's Avatar
Tim,
I wanted to jump in and suggest (as other have) an old SMC-'A' 28mm manual focus lens. I bought one for $90(USD) before a backpacking trip to California last year. I also took the trio of DA LTDs (21/40/70). The lens I used the most... was the 28mm. It's inexpensive, rugged, and has a great field-of-view for scenics. I don't like using AF for scenics anyway, and the focus-rings on the old MF lenses are much better for manually focusing (go figure )
-dak
10-17-2008, 07:47 AM   #21
Lowell Goudge's Avatar
What about a good bridge camera?
I know this is an SLR lens forum, but if space is that tight, why not a good bridge camera.
I use one quite a lot when travelling (especially on business) or when kayaking simply because I don't want to take my SLR and multiple lenses.
there are very good bridge cameras, the only real issue is that they don't go wide enough without a wide angle adaptor.
To keep on track, if you only have one lens, I would look at something in the range of 16/18 to 50/70mm, but go for speed and macro capability. If you are only taking one lens, it has to be reasonably versitile, but I would not consider the loss of speed and additional weight of a 18-250(ish) lens as justifyable.
10-17-2008, 08:45 AM   #22
I take my K10D and DA* 16-50 backpacking. It is heavy, big, gets in the way, etc...but it is a great performer, weather sealed, etc. I don't like having to change lenses when I'm out as a lot of my backpacking is in the desert and it is really easy to get dust on the sensor. So the 16-50 goes on the camera before I leave and doesn't come off.
10-17-2008, 09:02 AM   #23
RBellavance's Avatar
I have to agree with bdery here. If you own both, the Sigma is the clear choice: better range, faster aperture, better overall IQ, and close-up capabilities. It is larger and heavier than the DA18-55, but not so much as to be uncarriable, IMHO.
If you really need wider, the DA12-24 is a great choice. It is about the same size as the Sigma, but a bit heavier.
10-17-2008, 09:10 AM   #24
When backpacking, weight is critical, so it's up to you as to how much you want to carry. For me, I like keep things as light as possible, so I'll use a *istDS with a DA21, and *maybe* throw a DA70 in the bag too. I really like this combo, light weight without sacrificing image quality. I'll replace the DS with the new K-m as soon as they're avaiable as a body-only package.
10-17-2008, 04:41 PM   #25
Hannican's Avatar
More great responses! Thank you everyone for all of the input!
I think I'm going to try the Kit lens and see how that goes. If it fails me, I'll try the Sigma, but I still feel like it's too big.
I'm considering getting a smaller body too- perhaps an old istDS or even a K100super, but I don't really want to sacrifice resolution.
Are there issues with having the gear in cold weather? Will the camera/lens be ok just being inside my tent, or do you think I might need to keep them inside my sleeping bag at night?
Anyone have experience with this?
10-17-2008, 05:19 PM   #26
clawhammer's Avatar
if you're looking for a smaller body, wait for the Km to hit stores. small and light, with the same sensor (I assume) as the K10.
As for cold weather, there are two concerns: condensation and battery life. you'll probably want to keep the batteries close to a heat source (ie, your body). I'm not sure about the dangers of condesation, though.
10-17-2008, 06:19 PM   #27
Ed in GA
Guest
My $ .02 FWIW
I keep buying, and selling, the DA 16-45 f/4 thinking that I'm going to find a marvelously better lens.
So far, I've been wrong.
For a good wide angle, walk around zoom, I don't think you can beat the DA 16-45.
10-17-2008, 07:21 PM   #28
Raybo's Avatar
QuoteOriginally posted by Ed in GA Quote
Did ya get another 16-45 Ed?
I kinda like the one you sold me and thanks! It's a great lens!
Ray
10-17-2008, 08:54 PM   #29
Ed in GA
Guest
QuoteOriginally posted by Raybo Quote
Ray
Yes Sir... I sure did get another one. Absolutely great lens.
And.... I'm really glad that you're enjoying the one you got from me.
10-18-2008, 10:10 AM   #30
ballgofar's Avatar
I have to concur with the sentiments regarding the DA 16-45. I cannot recommend that lens enough. I took it with me to Alaska (lots if hiking, adventuring, etc.) and it was fantastic. To see some photos, check out the link in my signature; all those photos were taken with the DA 16-45 or a Tamron 70-300.
da, k-mount, pentax lens, sigma, slr lens
Misc Wide angle wllm Post Your Photos! 6 12-07-2009 09:57 AM
Which wide angle should i go for ?? Bossy Pentax SLR Lens Discussion 6 03-22-2009 05:05 AM
which wide angle? Ken Eremko Pentax SLR Lens Discussion 7 08-06-2008 09:53 AM
Wide Angle daacon Monthly Photo Contests 0 06-23-2008 02:00 PM
Which wide-angle lens for a KM? spray13 Pentax SLR Lens Discussion 5 04-14-2008 12:06 AM
All times are GMT -7. The time now is 05:28 PM. | See also: NikonForums.com, part of our network of photo forums!
