Originally posted by parinya-ekparinya However, I have no clue how equipping a teleconverter may cause some lenses to work with PDAF but not CDAF.
As I understand it only PDAF is influenced by AF fine adjustment. Therefore I suspect that, when a teleconverter is put between the camera/lens combination a new focus adjustment would be necessary for best focus results (which noone does for a handfull of shots before removing the teleconverter again) -> PDAF focus may get worse with the teleconverter applied.
The teleconverter also reduces the light by half a stop or a stop (I am not certain, I don't use teleconverters, just guessing here), depending on the maximum aperture of the lens this might has negative aspects for the accuracy of CDAF.
