To me it looks a bit underexposed and from the EXIF info it would appear to be so (about 2 stops under loony 11: ISO100, f/11, 1/100s). With a shot like this depth of filed wouldn't matter so I would assume that the f/11 was for CA control and I'm not seeing any of that, or was it to deal with a slightly off focus which I can guarantee you had unless you used a focusing mask. For a shot that is a day or 2 past full moon this isn't bad. the lighting in the center is the same as that harsh midday sun so there just isn't much detail or contrast to be had as there aren't any shadows. Another ting to consider is that the atmosphere is fairly turbulant which can cause areas to be out of focus which may also be a contributing factor to your perceived lack of sharpness.
You said you focused manually using live view but did you have focus peaking turned on? If I don't have a focusing mask when doing astro shots I will use live view with focus peaking turned off and then do star minimization. Having focus peaking turned on will bloat the star you are focusing on so it becomes harder to get that perfect focus. This will get you really close if done carefully, and it will be much closer than autofocus will get you but it will more than likely be off slightly unless you are just lucky. Typically
I use a bahtinov mask after minimizing a big bright star to really get the perfect focus. There are
generators for them that get you a svg image that
you can convert to stl file that you can get 3d printed. Once perfect focus is achieved I then frame up the object I want to shoot (they are all at infinity, even the much closer moon, from the lens's perspective).
When it comes to moon shots I usually start with a loony 11 equivalent exposure and do a quick test shot and adjust from there adding exposure until I get close to clipping the highlights. Then I blast away in burst mode hoping for the lucky shot.
Here is a shot I took of the full moon last month and it also shows the very flat illumination in the middle. 400mm ISO 200, f/2.8(wide open), 1/640s and it is a bit overexposed. This was focused using star minimization as I didn't have a focusing mask for this lens yet:
To bring out some the detail in the center I use unsharp mask but I still haven't figured out the best settings for using it on the moon so I got some haloing.
