10-15-2019, 10:02 AM   #1
DA* 60-250 modification help - Bay Area
Hello All,
I read the instructions to modify 60-250 to FF and they are very clear but, I don't trust myself performing the mod. As I live in the Bay Area, wondering if anyone in this area (preferably) could help modify my DA* 60-250 to FF.
Thanks.
10-15-2019, 10:22 AM   #2
BigMackCam's Avatar
Moved to lens discussion forum...
10-15-2019, 11:34 AM   #3
sergysergy's Avatar
I was hesitant too since I have zero skills but it ended up being quite easy. If you don't find anyone you should give it a try.
10-15-2019, 05:29 PM   #4
I also did the modification. I had a new baffle 3-D printed rather do a modification of the existing baffle. It was easy. I have been using it on my K-1 and I am getting great images.
10-15-2019, 07:18 PM   #5
Another vote for the modification. I also performed it myself and found it rather straight forward. Take your time and work carefully. The lens performs very well on the K1. Great lens
10-15-2019, 10:44 PM   #6
Modify baffle or 3d print one, any thoughts?
10-15-2019, 10:52 PM   #7
dave_roe's Avatar
I would attempt the modification if I thought I could pull it off. Here in Italy hard pressed to find anyone that will do the work.
So with that in mind I have just learned how to best use the lens on my Ki-II. Shooting at higher F stops seems to work fine and the lens works great on the camera.
10-16-2019, 05:28 AM   #8
bdery's Avatar
QuoteOriginally posted by garywakeling Quote
absolutely 3D print. Less messy.
QuoteOriginally posted by dave_roe Quote
I wrote the procedure, and can confirm that it's as easy as it sounds. Only a few screws to remove. I did it probably 10 times when writing the article.
10-16-2019, 06:47 AM   #9
Thanks everyone. I am now motivated to perform the mod by myself. I see the reference to file to print 3D baffle. However, any recommendation on getting the 3D printing done?
10-16-2019, 07:50 AM   #10
ChatMechant's Avatar
QuoteOriginally posted by godavari Quote
There's a place in santa cruz that does 3d printing called santa cruz electronics.
Good luck with the mod.
10-16-2019, 07:33 PM   #11
Thanks , less messy works for me.
10-20-2019, 10:27 AM   #12
Did it
Thank you all for sharing your experience with modification. That motivated me. I have used 3D printed baffle (thanks to my neighbor) and followed the instructions. First shots after modification looks like it worked.
10-20-2019, 07:06 PM   #13
You will like the results
10-21-2019, 05:13 AM   #14
bdery's Avatar
I'm glad it worked! Not that I was worried It's much easier than it sounds.
11-18-2019, 03:36 PM   #15
Here is a post taken with modified 60-250.
Fall Time - PentaxForums.com
da*, ff, pentax service, repair, service, warranty
SMC Pentax DA 60-250 F4 vs Sigma DC 18-250 F3.5-6.3 thepurplehornet Pentax SLR Lens Discussion 12 03-25-2019 10:22 PM
DA* 60-250 owners: How do you carry your 60-250 at the ready? apisto Pentax SLR Lens Discussion 25 12-30-2017 01:49 PM
Help! DA*200 or DA*300 or DA*60-250? TTQ225 Pentax SLR Lens Discussion 16 06-19-2009 11:05 PM
All times are GMT -7. The time now is 04:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
