10-17-2019, 02:53 PM   #16
Having both 8mm and 16mm fisheye lenses, albeit not the Zenitar, I'd caution about the amount of "fisheye-effect" you're likely to get on an APS-C camera with a 16mm lens. If you really want extreme distortion, an 8mm lens will be far more satisfactory, the 16mm is little more than a poorly-corrected wide-angle on the small sensor.
My Peleng 8mm was always "a bit of a novelty" on full-frame film, but really comes into it's own on APS-C, with only a little vignetting in the extreme corners of the frame. My Fujinon 16mm however, often a "weapon of choice" on film, gets very little use these days!
YMMV
10-17-2019, 02:56 PM   #17
BigMackCam's Avatar
QuoteOriginally posted by kypfer Quote
The OP is looking to fit the lens to a K1000 35mm film camera, so should do well with the 16 and 17mm fisheye lenses mentioned.
That said, I'd agree that the Peleng 8mm is great on APS-C But circular with the top and bottom cut off on 35mm / full frame...
10-17-2019, 02:59 PM   #18
Ooops! My mistake! sorry about that!
10-17-2019, 03:18 PM   #19
Just1MoreDave's Avatar
There's definitely a fisheye effect when you use the Zenitar FE on a K1000. I got used to using it on APS-C, but on film, everything is in the frame - fingers, feet, hat, etc. Stuff that you thought was behind you ends up in the shot. Only a slight exaggeration, you'll see if you try it. So check the frame before shooting. Also, don't lose the cap, the cap is unique.
10-18-2019, 12:25 PM   #20
QuoteOriginally posted by Just1MoreDave Quote
Definitely a fisheye effect, but is it a strong effect (the MC Zenitar 2.8/16mm Pentax-K)? Images of photos taken with the other lenses look a bit more warped/exaggerated in terms of the fishiness. Or is it just slightly more subtle with this lens? Just wondering as I am going for a somewhat dramatic fisheye effect while shooting skateboarders close up to the subject, often from underneath the subject.
10-18-2019, 02:19 PM - 1 Like   #21
Otis Memorial Pentaxian
QuoteOriginally posted by tp4379 Quote
Define "fisheye effect". Whether lines or horizon are bent depends strongly on the orientation of either to the lens axis. The Zenitar 16mm defines 180 degrees FOV on the frame diagonal for 24x36mm. Below are several 35mm film images; without knowing, which would one think were taken with the Zenitar fisheye?
10-18-2019, 02:22 PM   #22
They should look quite fishy enough, assuming the subject is close with major lines being off-axis. Near/far perspective takes care of itself the same as any other ultrawide.
10-18-2019, 02:30 PM - 2 Likes   #23
Forgot one...Should partially answer the skateboarder question as well as illustrating the lens axis behavior common to all fisheyes.
Scale is sort of strange on this one. The flags to lower left are full-size national flags and are not that far away.
(...was escorted off the premises by security after making this shot...)
11-03-2020, 02:50 PM   #24
I use this Zenitar on Pentax K200D, I'm very satisfied.
16mm, 17mm, adapter, camera, ebay, f4, fish-eye, fisheye 16mm zenitar, k-mount, k1000, lens, lenses, m42, pentax, pentax lens, pentaxk1000, reviews, slr lens, smc, thanks, zenitar, zenitar 16mm f/2.8
For Sale - Sold: MC Zenitar 16mm 2.8 Fish Eye (Full frame lens) M42 (M42 to K mount adapter included) kp0c Sold Items 1 01-31-2019 03:36 PM
For Sale - Sold: Zenitar 16mm Fish Eye Lens - K Mount Arjay Bee Sold Items 3 10-08-2015 03:16 PM
For Sale - Sold: Zenitar 16mm f2.8 fish-eye lens kennychung Sold Items 2 05-12-2014 12:37 AM
Pentax-A 16mm fish eye vs. 17mm Fish-eye-Takumar Nick Siebers Pentax SLR Lens Discussion 4 05-26-2010 03:51 PM
For Sale - Sold: Zenitar-K f2.8 16mm Pentax Fish-Eye topcaps Sold Items 8 05-21-2009 08:34 AM
All times are GMT -7. The time now is 10:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
