Originally posted by kiwi_jono What is the difference between "Nominal" versus non nominal values?
It is hard to say beyond pointing out that all four are in the Makernotes section of the EXIF and that the names are those pinned to these data by the ExifTool developers and interpretation is sometimes "best guess". I thought at first that MinAperture and MaxAperture are the values derived from the "A" contact coding on the lens base and that the "nominal" twins are those reported by the lens through the data contact.
Based on the EXIF from a recent shoot, the values for my FA 35/2.0 are :
Code:
Min Aperture : 22
Lens F Stops : 8.5
Nominal Max Aperture : 2.0
Nominal Min Aperture : 23
Max Aperture : 2.0
Moving to my Pentax-A 70-210/4 at 70mm, I get:
Code:
Min Aperture : 22
Lens F Stops : 8.5
Nominal Max Aperture : 1.0
Nominal Min Aperture : 6
(MaxAperture is missing)
and finally my Pentax-A 50/1.7:
Code:
Min Aperture : 22
Lens F Stops : 8.5
I threw in the Lens F Stops numbers because they may hold a clue. The revised theory might be that Min Aperture and Lens F Stops are derived directly from the mount contacts* and that the evil "nominal" values serve some sort of internal function with the locations possibly being used for different purposes (i.e. overloaded) depending on camera state. This is good except that there is not an 8.5 stop span for any of the lenses I sampled.** As noted by the developers, "Some of these tags require interesting binary gymnastics to decode them into useful values".
To paraphrase Inigo Montoya, "I do not think it means what we think it means."
* The mount contacts encode minimum aperture and number of f-stops.
** There are 8.5 stops from f/1.2 to f/22, the maximum number of stops possible with the base contact coding.
