Originally posted by pepperberry farm or you could continue to be mysterious and not tell us what lens it is....
It's a Photax-Paragon 135mm F2.8 prime, but either this lens, or the Helios 44M-4 that did recently break on me, used the m42 adapter. As i'm not really planning on repairing the Helios, i'm just looking to use what i already have. Sorry for having bills to pay and not willing to spend money on something i already have.
Originally posted by GUB I have several lenses that I have bonded an infinity adaptor to. It is critical to remove that little spring otherwise the lens will be irretrievably locked on to your camera. Downside to removing the spring is the lens is no longer locked at all on to your camera. I have regrets gluing the adaptor on as often the non infinity adaptor is more appropriate for general use.
Yep, i lost the spring anyway while adjusting the adapter so that's something i already accepted. Not too well, not too bad, but the spring isn't already there. I might just poke a hole on the lens to make it latch with the K mount pin and somewhat lock it
Originally posted by Not a Number What am I missing? You say you have a 135/2.8 m42 lens and then you say you don't own or plan to own any m42 lenses. Is it borrowed?
The only way to attach the adapter semi-permanently is to either use a "breakable" adhesive like a thread locker or to add grub or set screws to the adapter. These will mark and damage wherever they contact the lens, i.e. the mount threads.
And something is wrong with either the lens or the adapter if you had to modify the adapter to get infinity focus if it is a non-flanged (lock spring type) adapter.
Yes, i don't plan to own more m42 lenses that i already do, but this lens is solely mine. I might look into a thread locker, as i can break this bond with my extension tubes if needed.
Originally posted by GUB Or the lens needs adjustment.
When i got the adapter, both lenses wouldn't really focus to infinity, but while on a MZ-50 body (plastic mount) would be almost spot on, looks like my K-5 has a thicker mount or whatever and wasn't able to focus to infinity. Also the adapter was visibly not flush with the camera, so i went ahead and dremeled the heck out of it, and it worked fine.
