Originally posted by motorhead9999 Other than being able to control the aperture with the camera body, is there an advantage to the M vs A optically? Or is it just a build quality preference?
One thing at least is metering mode. You don't get matrix metering with M lenses or earlier. I have both M and later lenses, and much prefer the later AF lenses (basically same as "A" except for having AF) as they are much faster-responding than using the green button, which I also have found is not all that accurate and changes depending on which aperture is selected. Metering, even using spot or center-weighted, with A or AF lenses vs M lenses for me has been more accurate.
---------- Post added 10-31-19 at 09:12 AM ----------
There are more advantages with the FA 43mm LTD: build quality is first-rate, its MF feel is very good and smooth, perspective for shooting scenics is just as the eye sees it. Front-to-back ratio between objects or of the same object is accurate. There is no elongation or compression. This perspective accuracy was the reason for designing it with the odd FL- 43mm, which is especially useful on a FF body for which it was designed. I used mine for years with 35mm film. If I should get a K-1, it would again see more use. I think Pentax should upgrade this model by having HD coatings as they have with the FA 35mm f/2. Image quality is excellent.
With the FA HD 35mm f/2 you can get exceptionally fine edge-to-edge performance right from wide open on, and at a reasonable price. MF feel is ok, probably improved by the look of it on the newer HD version. Image quality is excellent across a large aperture range.
Even the DA HD 40mm f/2.8 Limited could be considered, especially for landscape use, as it has shown to have excellent edge-to-edge sharpness across its aperture range, even at f/11, to an exceptional degree! It is said to be cut large enough for FF use, and would be even smaller on a K-1 than the FA 43mm LTD, and far less expensive for a new one. It would look and handle phenomenally as a combo with the K-1, making for a "compact FF DSLR"! Again, build quality is first-rate and MF feel is very smooth. I use my older non-HD version on my KP, K-S2, or even on my larger K-5 IIs, but it would also see more use if I had a K-1, especially when I need top quality edge-to-edge performance. You'd need a different hood than the one supplied for APS-C coverage, due to the wider FOV on the K-1.
