Originally posted by BruceBanner Oof! Awesome! Except I can't make out much on that diagram picture lol, is it available anywhere in a larger size? hehe
If I can find a bigger image, I will post it here. You can also try the link below; it is a bit bigger but not much.
http://tokyoscape.info/go/zz-share2public/da15/disassemble.jpg
If you can remove the metal O ring, everything will be quite simple after that. Turn it counterclockwise with a rubber or something. You will see the 4 screws below it. Remove all of them and you can pull out the hood + the hood holder part quite easy. It will come out together.
Then look at it closely you will see 2 tinny metal parts that block the hood from slide off the rail. Rub them off with a rasp or something. Don’t do too much. Just enough to free the hood. The hood can be installed back any time after that too. Then you want to put the holder, the screw and the O ring back together. Don’t forget to clean up the Hood’s holder before you put them back. Tinny metal dust can kill the lens.
Before you put things back together, you might notice another 4 screws below. They are important to keep the lens together and function. 2 screws of my 15 were loosened and the lens wobble like it is about to split apart + auto focus stopped working. That’s why I open it up in the first place. If you already go this far, I think you can make sure all the 4 screws are well tightened. For anyone with the same problem, this is the place to fix.
You can but should not do it, turn the lens group counterclockwise to entirely remove lens group. No point of doing that but it satisfies my curiosity's sake! I guess if the lens is de-centered, this might be the place to fix.
