Based on the pictures I saw on the Web, the Promaster is a Cosina lens. I have the other kind of 19-35mm lens that was available with the same specs but was made by Tokina. I would not be surprised if the lenses are a collaboration between Tokina and Cosina (and maybe even Tamron because they also had an identically spec'd lens) - but the Tokina has the best build and the Cosina versions were mostly just made with plastic. But optically, they're similar from what I could gather - capable of very good results if the light is right, but once you have a strong light source you lose contrast and they also flare easily.
The Tokina 28-70 is said to be a good lens but the Pentax 24-70 will be a better lens, especially wide open. Flare would also be an issue, like with all older Tokinas.
The F 28 2.8 is a good lens and from pictures I have seen, it's very good even wide open. I'm not sure if it would be better than the 24-70 at 28mm but I think the latter would be at its stronger point there, so I suspect it would do very well.
So, while your lenses are nice, and it's nice to be able to go down to 19mm, I would still consider the DFA 24-70 to be an improvement over your 3-lens setup. Still, your current 3-lens setup should be capable of very unique pictures and the lenses have a lot of "personality" - which you might miss, or you might not
