Originally posted by Igilligan do you mean it is not locking focus in that range or that the pics are blurry with a locked on AF?
Thanks for all the responses, I am returning this copy.
The symptom is, when focal length is set between 90 to 135mm, even at the
maximal 2.8, I could not get the focus locked (the focusing light flashes, and in
AF.S, I could not click the shutter).
If I move the focal length to < 90mm, the
lens focuses fine.
In the 90 to 135mm range, the lens tries to get focused by moving back and
forth for several times, and finally would give up, with the flashing focus
indicator.
I could focus with a smaller focal length, say 70mm, move up to the 135mm,
in which case, I could keep the focus.
Manual focusing works fine.
This affects my confidence in the Pentax SDM, with the other post on DPReview,
about the 16-50
failure .
