Originally posted by nbs2222 Hi, I’m pretty new to using classic lenses on DSLR and I’m not sure if a filter, particular UV one, is needed. I’ve been reading on quite a lot of sites and some said that old lenses, unlike newer lenses, do need a UV filter, while some said it does not mater. So I’m unsure right now if I should buy it. (If I buy, it would be the Hoya fusion antistatic UV filter)
I’m currently using the SMC Pentax 30mm f2.8 on a Pentax KP.
Any help is appreciated, thanks!
We've been around and around on this a few times now. The short answer is no, no, no, no, no, no, .......
I have had that 30mm lens for many years. The SMC coating and proper handling will get you the best image quality and then post-processing of some sort is usually applied anyway while using a DSLR. It's far more important to use the best suited hood on your lens and use the lens cap for protection when you don't need to see through it. The use of UV or "protective" filters was virtually never needed by anyone at the time that lens came out and absolutely redundant now for a digital sensor. When I worked at a store UV filters were sold only if a customer with old school thinking insisted on it. Those may have been justified many years earlier when photography was done with little to no coating on lens elements and the films were more sensitive to UV.
It's best not to introduce any unnecessary item between your subject and your expensive modern optical formula.
