11-14-2019, 02:19 PM - 2 Likes   #1
kcjonez's Avatar
DA20-40Ltd lens cap issue.
When I got my DA20-40 a couple years back, I noticed the lens cap could be knocked off if it brushed up against something. Over time it has loosened to the point where it simply falls off when i am walking. I have lost count of the times I have retraced my steps to find it, yesterday being the most recent. It is a friction fit flocked cap and I assume the flocking has become compressed or lost over the years. There are no threads inside the hood, So.......
My question is, has anyone found a solution to keep the original lens cap on or any other solution. The hood is not threaded and I haven't found anything to fit it that stays on.
A few ideas, neoprene lens hoods? Has anyone tried them on the 20-40".
Using a 55mm-62mm step up ring instead of the hood and a 62mm pinch cap? Or a 55-58 & 58-62?
Adding more flocking or re-flocking the original lens cap?
Ideas appreciated, practical experience more so. Thanks in advance.
Photo to illustrate why I love this lens. 20mm on K-3.
PENTAX K-5 II  Photo
11-14-2019, 02:25 PM - 5 Likes   #2
Seeker of Knowledge
aslyfox's Avatar
I have done this with my DA 40mm XS which also comes with a friction fit cap
I got a cheap uv filter and glued the cap onto it
I then screw in the filter and cap into the lens
_____________________
another thing I have done with other lenses I get a filter stack cap
Fotasy 55mm Metal Filter Stack Caps, Filter Stack 55mm, Aluminum Alloy, Slim Stack fits 55mm UV CPL Fader ND Filter
https://smile.amazon.com/Fotasy-Metal-Filter-Stack-Aluminum/dp/B07S8R5YDS/re...766915&sr=8-19
and take the male part and use that as a screw in cap
and just store the original cap
11-14-2019, 02:37 PM - 4 Likes   #3
Otis Memorial Pentaxian
I don't take my friction-fit caps into the field. Pinch caps are cheap and generally stay on, problem solved.
11-14-2019, 02:39 PM   #4
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by aslyfox Quote
These are solid suggestions aslyfox! Thanks for sharing! Brilliant
11-14-2019, 02:49 PM   #5
UncleVanya's Avatar
Mine only falls off in the bag so far. But after looking at it it will be a pain later. The hood doesn't have any threading on the cap end so a solution using a pinch cap may require a hood replacement also.
On some other lenses I have obtained metal hoods with integrated pinch caps - in the old days we would raid Tupperware at the thrift shop and find a matching diameter.
Here's my 50-135 wearing an alternate hood with integrated cap:
Generated from my Motorola o using tools.sportscard.trade
Btw the hood in question adds a slight vignette. I need a little wider diameter. The length is perfect.
11-14-2019, 02:52 PM   #6
I also noticed this problem with my 35 Ltd yesterday. The cap fell off in my bag while I was walking. The suggestions by aslyfox are great. I was just thinking about this myself and you could also apply a thin ring of foam or rubber lining to the hood sides but I'm not sure how well that would stay or how long it would remain intact for.
11-14-2019, 02:54 PM - 1 Like   #7
Seeker of Knowledge
aslyfox's Avatar
Mine only falls off in the bag so far. But after looking at it it will be a pain later. The hood doesn't have any threading on the cap end so a solution using a pinch cap may require a hood replacement also. . . .
for some reason, I seem to knock off pinch caps from time to time
so I like the screw in caps
" to each his own " of course
11-14-2019, 03:04 PM   #8
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by MikeyBugs95 Quote
. . . I was just thinking about this myself and you could also apply a thin ring of foam or rubber lining to the hood sides but I'm not sure how well that would stay or how long it would remain intact for.
if you ever might want to sell
doing something to the original cap might be objectionable to a purchaser
11-14-2019, 03:15 PM   #9
kcjonez's Avatar
Thanks for the tips! I also prefer screw in caps. Potential cost, a few seconds removing. Potential gain, No lost caps or uncovered glass rattling around somewhere.
11-14-2019, 03:25 PM   #10
I don't have the lens but I had an old vivitar zoom (70-150 if I remember well) that had the same type of cap. The old velvet lining lost friction and the cap fell constantly. I carefully remove the old velvet and replace it with a strip of self adhesive velvet flocking liner.
11-14-2019, 03:32 PM   #11
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by kcjonez Quote
the filter stack caps are metal
so a little more protection than plastic
but you do end up with the female section just sitting around
11-14-2019, 03:35 PM - 2 Likes   #12
amateur dirt farmer
pepperberry farm's Avatar
^^^ this ^^^
I only use friction-fit caps when the lens in not on my camera - once I mount it, I add a pinch-cap and leave the OEM cap on the desk...
11-14-2019, 04:28 PM   #13
I leave my old Takumar friction lens caps at home and use only cheap pinch caps in the field.
11-14-2019, 04:47 PM - 1 Like   #14
I don't have a 20-40 but my 10-17 use a similar cap style. I always buy clip-on plastic caps from eBay or use the old FA's version. Just make sure it large enough to fit the open of the hood.
But once a lens attached to my camera, I usually don't put a cap on the lens. One hand cover the open of the hood while walking most of the time.
11-14-2019, 05:26 PM - 1 Like   #15
ramseybuckeye's Avatar
I have had the 20-40 for just a short time and my cap stays on. I imagine when it starts to slide off I will probably apply a thin layer of rubber cement inside the lip of the cap, but that would probably no last too long. After reading this thread I tried a couple of ideas. A 62mm pinch cap fits on the hood, but can be pulled off rather easily. I put a 49mm cap inside the hood, but it was too hard to remove. without removing the hood.
cap, da20-40 ltd, da20-40ltd lens cap, hood, ideas, k-mount, lens, lens cap, pentax lens, slr lens, solution
For Sale - Sold: HD DA20-40mm LTD, SMC DA15mm LTD, DA50mm f1.8 ncinense Sold Items 12 08-14-2018 12:15 AM
DA20-40 weird AF issue Paulo Troubleshooting and Beginner Help 5 12-31-2017 11:46 AM
K-1 paired with DA20-40 Ltd crop lens aleonx3 Pentax K-1 & K-1 II 3 11-06-2017 07:44 PM
Need a water resistant lens for travel/hiking...18-135WR or 20-40ltd? Alnjpn Pentax SLR Lens Discussion 13 03-25-2016 05:49 PM
Llive view (CDAF) AF problemswith SMC 40ltd Jannis Pentax SLR Lens Discussion 2 11-02-2014 04:43 PM
All times are GMT -7. The time now is 08:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
