Well thank you everyone for weighing in with their 2 cents. It seems quite a divide, a lot suggesting the genuine article whilst others suggesting cheap ones are fine. I wouldn't mind the genuine article so much... but its $129AUD! That's quite a step up from the $5-10 I was thinking I'd be paying. However I do want to look after this Tak 50, I've seen what it can do and if it is a good copy will most likely come with me to the grave
Originally posted by stevebrot Yes, one can using Loctite, though it would not make sense with other than the cheapest adapters. Of course, the retaining spring must be removed, leaving the lens potentially able to rotate off the camera (no retention pin).
No, they are not all the same. The brand-X are fundamentally different in fit and action than the genuine Pentax. Simply put, brand-X fits tight in the mount with registration defined by the adapter, while the genuine fits loose with registration defined by the face of the camera's K-mount flange. The tight fit might be a concern due to possibility of the adapter creating metal shards by action of poorly-machined edges against the body mount tangs. Metal dust on the mirror and in the mirror box of one of my film cameras was a side-effect of my brand-X adapter experiment several years ago.
There are other differences in how the tangs are machined on the brand-X versions that makes them prone to becoming stuck on the camera unless the retention spring has been removed. Some users on this site have resorted to use a Dremel tool to cut the adapter out of the mount.
My advice is that get a genuine adapter and leave it on the rear of your new lens along with a K rear cap. It will mount fast just like a regular K-mount when you need it with the adapter easily removable (takes less than a second) when you are done. It only takes a few more seconds to spin it back onto the back of the lens, ready for next time.
Sounds good, and will probably be my first port of call. My hesitation and somewhat seeking a permanent (even possibly gluing) the adapter is more to do with how I shoot events. When I do weddings and such I do lens swap frequently, and it can get a bit frantic at times, stuffing lens caps in pockets and what not, I'd hate for a shiny metal adapter to see its way into a lens pouch and start scratching some neighbouring element
So my thinking process was to keep the two together at all times to limit the liklihood of losing the adapter on a job, adapter being loose somewhere and scratching something, or worse getting the adapter stuck on the camera at critical moments.
Originally posted by luftfluss I currently have several m42 lenses, and each one has a $10 adapter on it, spring removed, hand-tightened. The lenses mount and un-mount from my DSLR's as if they were native K lenses.
Of the dozen or so adapters I've used over the years, 2 have been problematic - one got stuck on the camera (used the tool to remove it) and one did not permit infinity focus. Otherwise, they've been fine.
Good to know.
Originally posted by pepperberry farm you don't need to remove the adapter at all if you have a second body to become your M42 body....
Well that is true, and a good reason not to glue as well, if for example I pick up a m42 body some time in the future?
Originally posted by mlt Just don’t glue an adapter to that 8 element Takumar. Never a good idea for any Takumar, even more so for a rare gem.
Yeah I had thought about that, I don't think I will do the permanent thing...
Originally posted by Sandy Hancock Another vote for the genuine Pentax Adaptor K for M42. I have used the cheap knock-offs and the difference in quality and ease of use is striking.
Ok, good to know, thanks again Sandy.
Originally posted by mlt True, never any question about registration distance, fit, or finish with the genuine article.
Yeah... something makes me think that if I had a cheap one and something wasn't right I would always be wondering if the genuine was better...
Originally posted by kiwi_jono I don't have that many adapters (maybe 4 or 5) but this strategy works for me. Removing the spring makes M42 lenses them much more usable IMO.
Only disadvantage is the lens is not locked in place but for the adapters I have they are tight enough that my lenses have never shown signs of loosening while using (focusing etc) the lens.
Good to hear that without the spring things still feel semi tight. I wonder if there is a trick you can do to further hold the lens in place, like fixing an interesting lens hood that has provisions for an elastic band or something to dock onto the hood and then be tensioned back to the camera body (perhaps to the tripod plate)? Yes... I am that crazy to rubber band this thing...
Originally posted by Aaron28 have several knock off adpaters….some I have removed the 'spring' others I have not.....have considered gluing ( blue locite was a choice to do so) but have not which has been a good choice now that I have a few m42 bodies I am running film through and can use the lenses readily n easily....
will also note my K-50 is the body for m42 adapted lenses...on rare occasion will place on the K-3ii and have refused to use any on the K-1 because they (adapters) have gotten 'stuck'
Thanks Aaron.
I guess I am siding more towards getting a genuine adapter. Has anyone removed the spring of the genuine and felt the lens once screwed in and adapter fully twisted into the right positon that it feels quite loose? I'm wondering now with the spring removal hack if some 3rd party ones are tighter than the genuine article?
---------- Post added 11-18-19 at 07:58 PM ----------
Originally posted by Dipsoid The removal is not a pain IF you use the genuine Pentax adapter. You use your fingernail and it's really simple. M42 lenses often work fine in av mode if they have a manual switch for the aperture. The viewfinder just gets darker as you close down the aperture.
Oh, ok, so that sounds the same as how the lensbaby lenses work in Av. Aperture does work but viewfinder acts like it is permanently doing the 'Optical Preview' thing, which is good on one hand as it negates needing to use that feature, but bad on the other in that the viewfinder gets dimmer.
The Tak 50/1.4 also has a A and M switch? I take it due to lack of connections you cannot control the aperture from the body... but then what is this lever switch for?
