Originally posted by photoptimist The Sigma 12-24 DG deserves some consideration, too. It is AF but does not support filters other than thin slip-ins behind the lens. It's very rectilinear and nicely sharp on the wide end.
I also have the Samyang/Rokinon 14/2.8 which is great for astro but does have a strange "mustache" distortion that some don't like for architectural shots.
Another vote for the Sigma 12-24 here too, I used it for years on Film, used it on crop APS-c all these years until, I could use it again on my K-1.. It's wide, very wide. You can actually put a filter on the front, if you only remove the lens cap itself, and not the whole cap, but it will vignette when doing so.
There's also the Sigma 15-30 as well, I bought one just when the K-1 was coming out, and it's also very good, I only replaced it a year or so ago with the DFA 15-30, when I was left some "Coin" from an elderly relative, who knew I loved photography.
I also have the Sigma 14mm/2.8, AF yes, but mine sufferred the same as most I believe, the focus tightened up, AF could not work, and even the manual focus was stiff, actually this was kind of OK as when you set the focus, it stayed there, I liked it, but , it does have a lot of CA.
