11-21-2019, 11:03 AM   #1
problem pentax A 28mm f2.8
Hello everybody. I had already had problems with mushrooms with this lens, but I had solved them by removing it from the front. Today, instead, I tried to take pictures and discovered that the diaphragm didn't open and close. Consequently I thought to disassemble the back part in order to verify the problem. Here, the problem I solved it, but while I was removing the back cover, the spring contact of the selector "A" was released and jumped out. Fortunately I recovered both the spring and its metal cap, but I can't understand how it should be reinserted. I see that there is a small milling on the cap, and I am wondering if there was a seger ring in it. Can anyone give me confirmation?
Thank you in advance.
11-21-2019, 12:14 PM   #2
Not a Number's Avatar
The bracket/contact you have circled pulls out. The pin fits into the contact from the right hand side as is oriented in your photo. You sort of tilt the top of the pin to the right (as pictured) and the grooves engage with the contact and straightens out. I find it easier to assemble with the spring in place.
See the thread linked which shows how the contact assembled. If you use grease on the assembly make sure it is conductive or else you have to take it apart again to clean off the non-conductive grease.
Pentax-A 50mm f1.7 Aperture ring repair - PentaxForums.com
cap, pentax a 28mm
Kiron 28mm F2 MC or SMC K Pentax 28mm F3.5 ? chapolin Pentax SLR Lens Discussion 69 02-06-2019 12:15 AM
For Sale - Sold: Vivitar MC 28mm f2 + IMAGE MC AUTOMATIC 28mm f2.8 anakhaled Sold Items 3 10-26-2017 04:16 AM
Wanted - Acquired: SMC Pentax 28mm F3.5, SMC Pentax-DA 35mm F2.4 AL, SMC Pentax-F 28mm F2.8 TMoneytron Sold Items 8 07-15-2012 02:54 PM
The Soligor 28mm f2.8 or the Vivitar MC 28mm f2.8? kelvin.wong Pentax SLR Lens Discussion 11 04-26-2011 07:20 AM
Soligor 28mm f2.8 M42 vs vivitar 28mm f2.5 M42 NaClH2O Pentax SLR Lens Discussion 3 04-11-2011 11:16 AM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
