I really WANTED to love the Pentax DFA 15-30... (I shoot landscape genre, primarily).
Upon receiving my second copy (first similarly failed my tests) of the DFA15-30 from Amazon (B&H), I conducted very careful (tripod, e-shutter, delay timer, careful focus using max-zoomed live-view) lens tests and found serious trouble at ~20mm f8 (which should be a sweet spot!). It did better at 15 and 30. Online reports like
HD PENTAX-D FA 15-30mm F2.8 ED SDM WR Review | ePHOTOzine don't hint at any situation like this.
As shown below, in the center area of frame, my copy of the DFA15-30 could not come even close to matching a 20 year old FA20-35 at f8 - the DFA is SIGNIFICANTLY softer in the important center area. Incidentally, my first copy result was similar. It began to outperform the old FA by f13, but that seems ridiculous to me, and doesn't jive with some online review test results which showed peaking resolution at f8. And is not acceptable for a $1200 new-technology lens vs. an affordable OLD old lens. Below are side-by-side high-zoom (like 200-300%) comparisons (lens noted on title bar – some are in reversed order). So the good news is that I already have a MUCH lighter, smaller, easier to carry ultrawide zoom in the FA20-35 (which is ALWAYS in my bag)! I should be happy, I suppose! Maybe I just have a "golden" FA20-35 and my expectations for the DFA15-30 (at 20mm) are unrealistic! But I doubt. I'm tempted to try a third time, but, maybe I just stick with my FA20-35 plus Rokinon 14mm for the wide end (which is competitive with the 15-30 from my tests, although I prefer the 15-30 rendering at 15 vs. rokinon14).
Just for context- I've attached a "full-image" shot (DFA at 20mm f8) from the indoor scene, just for context. Just to reiterate- both images were carefully and precisely focused on the center objected using max-zoomed live view (i.e. no "autofocus error" going on).
Any others out there who have carefully tested the DFA15-30 at ~20mm f8 and compared to an FA20-35 or even A20?
________________________________________________________________________
UPDATE - third lens received, tested, and passed muster.. "if at first you don't succeed, try, try again...". (Thank GOODNESS for easy-peasy no-cost-to-me return via Amazon). Seems odd that I received TWO problematic lenses (second one was even worse than first). But the third one is good, and in line with what other (glowing) reviews report, like NORTHCOASTGREG et.al. At 15mm, wide open, I do find some coma on stars in all corner areas (radial away from center) - I'll have to do some head-to-head compares with my beloved Rokinon 14, but my intent was to switch to this 15-30 for all astroscape. I haven't tested the 20-30mm range - perhaps improved and that gives great option for astroscape framing..
