Originally posted by Sir Nameless Do you have some? What's your experience with them?
Easy to get on & off? One-handed?
Do they stay flexible in the cold?
Do you think they would tear easily?
Do they work with really small lenses?
I own 4 Kuvrd Lens Caps, 2 Micro and 2 Macro that came as a single package, a good introductory offer.. Unless you have lenses with a filter diameter greater than 70mm, the Micros will satisfy your needs.
Easy to get off and on one handed, with practice, though the larger diameter lenses may present a challenge.
I haven't tried them in sub-freezing temperatures, but even in low temps they remain supple.
I use a Micro on the FA-77mm, which is a fairly narrow lens, and a Micro works well with it.
I use a Micro to cover an M42 17mm FE lens, which has a bulbous and difficult to cover front lens, the Micro is great for covering and protecting the lens.
I did receive one with a pinhole tear in the cover, but their customer service quickly replaced it, otherwise they have been very durable.
