Originally posted by peggers
I'm interested in another aspect of this question (Also using Pentax k5). By using a Sigma lens, is it true to say that some of the functions of an external Pentax flash will be not available? I've noticed that when using a Sigma 18-200 lens with a Pentax flash the results are far from consistent. Exposures will vary quite a lot. I have noticed that when using the Pentax 18-55 lens that all of a sudden the results when using the Pentax lens give perfect exposures almost all of the time
As to the shadow from the built-in flash, this is because the size of the lens is causing it to be partially in the way of the flash output. Pentax does make a neat little hot shoe flash that has WR construction, and is not costly. It is so small it can easily be carried in a jacket pocket or takes up very little room in a camera bag. It also has more power than any bill-in flash of my acquaintance. But if the photography is takingrlce outside in bright daylight, and only some fill-flash is needed, there will probably be no detectable shadow from just the regular built-in flash.
The above is an interesting question. Indeed, lenses do feed info back to the camera, and some 3rd party lenses might be somewhat deficient in this regard. OTOH, I have numerous lenses by Pentax and 3rd party, yet have not noticed a discrepancy. Not to say it doesn't exist. But one thing the flash system is supposed to do is modify its flash angle according to the FL of the lens, yet there is a limitation for this. 55mm is well within that limitation, but a FL far greater, certainly 200mm, will not be reached, so the flash output will be more dissipated beyond the framing.
