Originally posted by hadi Sure, 1.4 is a shallow depth of field that may not be the most usable in all settings, yet if it's perfectly usable on an 85mm lens, then there is no reason why it can't work in a 50mm.
As in, I use my 85mm 1.4 wide open all the time and I never suffer from soft images.
The difference between IN FOCUS BUT SOFT, vs MISSED FOCUS DUE TO SMALL DOF is not the same.
I believe the 50mm 1.4 that I have is known to have soft images wide open.
I agree with this completely...
I find that I tend to use my 50mm and 85mm lenses wide open only when doing portraiture at close to their respective minimum focus distances.
Because my 85mm lens has a fairly long MFD, depth of field in practice between the two lenses is about the same at f1.4.
And my 85mm and 50mm are both known to be "dreamy", "soft", or whatever other adjective you want to use to describe a lack of complete sharpness when they are wide open.
That said, I have bigger issues with subject/photographer movement ruining the focus since most of the time, I'm handheld when I do this.
Most of the time, when I use either lens wide open, I'm after that "dreamy" look, but I still want things in focus that are meant to be in focus, so yes, these things are different...
I am a big fan of the 50mm f1.7 for its relative sharpness at wide apertures and its bargain price, but I think the DFA is the only lens out there that is totally solid at f1.4 (and everywhere else).
-Eric
