12-17-2019, 05:07 PM   #1
Lens hood for DA* 55mm Lens on K-1
Can anyone recommend a lens hood to use with the DA* 55mm lens on the K-1 in full frame mode? Specifically to minimize vignetting.
Thanks
12-17-2019, 06:47 PM   #2
Online ebay hard metal ones for a few dollars from China, just put in filter size and metal hood, they screw in and work very well in a "standard" length
12-18-2019, 08:05 AM   #3
pid
I like the short vented hood on my DA*55. You can continue to use the original lens cover.
12-26-2019, 04:36 PM   #4
dcpropilot's Avatar
I just correct in post. Haven't had too much of a problem.
12-26-2019, 04:51 PM   #5
Sandy Hancock's Avatar
I use the OEM hood. Physical vignetting only occurs in the extreme corners, and can still happen with the hood off.
12-26-2019, 05:36 PM - 1 Like   #6
SSGGeezer's Avatar
If you don't have an original, look for one that fits the DA 55-300 PLM and it does a pretty good job. My DA*55 hood is cracked so I just pull the one from the PLM and find it works great. There are Chinese copies on the bay for under 10 bucks.
12-27-2019, 07:33 AM   #7
Thanks, I was thinking that the original hood caused some of the vignetting, so something wider and shorter would help. Has anyone tested it with and without the hood?
01-01-2020, 11:32 AM   #8
PH-RBJ 58mm lens hood on DA* 55mm Lens
Does any one know if a Pentax PH-RBJ 58mm lens hood will fit on a Pentax DA* 55mm lens. The PH-RBJ 58mm lens hood is made for the HD DA18-50mm WR RE Lens. I notice that when I use the original lens hood for the DA* 55mm lens on the K-1 in full frame it does increase the vignetting some. I would think that the PH-RBJ 58mm lens hood since it is made for use on a zoom that goes to 28mm equivalent in full frame would be less likely to cause vignetting.
Happy New Year All
01-01-2020, 12:30 PM   #9
amateur dirt farmer
pepperberry farm's Avatar
or just a just a generic screw-in 58mm hood?
01-01-2020, 12:57 PM   #10
Just1MoreDave's Avatar
This generic hood for the DA 55-300 lenses fits the bayonet mounts on the DA* 55/1.4, reverses, even has the polarizer window. I don't know about vignetting but it was cheap so I'd just saw off parts until vignetting wasn't a problem any more. Unfortunately Amazon says it's not available now. A more comprehensive search might turn one up. I'd be happy to trade my JJC for an original DA* hood.
amazon.com : JJC LH-RBG-58MM Bayonet Lens Hood Shade For Pentax SMCP-DA 55-300mm f/4-5.8 ED Lens Replaces Pentax PH-RBG : Camera & Photo?tag=pentaxforums-20&
12-14-2020, 02:02 PM   #11
UncleVanya's Avatar
This thread is older but I can confirm that on a Sony A7RII the vignetting is slightly worse with the hood on.
ILCE-7RM2  Photo
ILCE-7RM2  Photo
12-14-2020, 09:00 PM   #12
I have just been using it with out a hood and the DA*55 is not bad on the K-1
55mm, 58mm, da*, da* 55mm, da* 55mm lens, hood, hood for da*, k-1, k-mount, lens, lens hood, pentax lens, ph-rbj, slr lens
For Sale - Sold: DA and HD DA Primes: DA 50 1.8, DA XS 40mm, HD DA 35mm, DA 21mm, HD DA 15mm Amarony Sold Items 8 02-20-2019 06:21 AM
For Sale - Sold: DA*200mm, DA*300mm, DA 12-24mm, 18-55mm II + hood (Worldwide) Albert Siegel Sold Items 7 08-30-2010 04:35 AM
DA 18-55mm AL II vs DAL 18-55mm (kit lens) vs DA 18-55mm WR rustynail925 Pentax SLR Lens Discussion 10 01-08-2010 02:06 PM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 10:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
