Originally posted by Gingerthecat I saw a lens by Ricoh described as a Toy lens. Fixed focus etc Q 05 18mm and it was unbelievably cheap, £10 for a brand new lens. I hadn’t heard of the Q mount before: is there a converter to PK and if there is, would it ruin the focal length?
I know that one can obtain toy lens effects with Lensbaby, which are many times more expensive and one has to bear in mind that over here in the little old UK, we’re all poor as church mice. Is there any other kit to produce a similar effect? Ever since I had a toy camera as a child, from Woolworth, I’ve been attracted by the quirky pictures I used to take.
Happy Christmas to you all.
If you're a little bit handy with a hacksaw, drill and a file, find yourself an old Brownie 127, disassemble/wreck it sufficiently to leave yourself with just the (single element) lens and surrounding mount and aperture plate, then take a plastic body cap and make a half-inch or so hole in the middle of it, alternatively a T2 mount or short extension tube may be pressed into service.
Using whatever resources are available ... cardboard tube, sticky-back plastic, blue-tack etc., mount the lens suitably in front of the hole in the body-cap or in the T2 mount or extension tube, then fit the whole to the camera and bingo ... 'toy' lens
A little amount of adjustment will be necessary to get the focus right, then you're good to go ... a lens hood does improve things
Don't forget to set the appropriate menu choice to "Use aperture ring" to enable the shutter to operate without a "proper" lens fitted!
Point to consider :
Many/most "basic" 35mm or Instamatic cameras have relatively short focal length lenses, to enable them to be "focus-free". Unfortunately, for this purpose, this also means that they would need to be mounted too close to the sensor (too deep into the camera body), to be practical. Hence the choice of the longer focal-length lens from a 127 camera
Alternative commercial options have included the Itorex "Pan-focus" lens, a 50mm unit with a fixed f/40 aperture and a T2-mount, also there was a fixed-focus 35mm f/5.6 in K-mount variously branded "Prinzflex", "Cherry", and others which was basically an extension tube with interchangeable optical units, one of which gave a taking lens, the other giving a 2x adaptor ... strictly novelty value, but it might be what you're looking for
A little further "research" has turned up the Loreo "Lens in a cap" solution ... I've no experience of this, but mention it because it looks like it might be fun
Reason: Further research
