Originally posted by ChristianRock I think buying the fisheye and useing APS-C when you need WR makes sense, if those are your options...
Thank You. That is exactly what I was thinking
---------- Post added 01-04-20 at 12:25 PM ----------
Originally posted by barondla The cool thing about the new 10 -17 is it gives 2 looks. Circular fisheye (actually not quite circular, the top & bottom are cropped very slightly) to full frame fisheye. Zoomed up to fill the full frame sensor, it has the same field of view as the 17-28 fisheye at the at its 17 fisheye setting. It could be argued that on ff only the 10-17 stays fisheye over the whole range. The 17-28 doesn't appear like a fisheye at 28.
Keep in mind the 10-17 does fisheye on both APS-C and ff cameras. The 17-28 won't. One other point, when the original 10-17 came out Pop Photo's Herbert Keppler loved the much closer focusing vs the 17-28. This is important because a lot of FE shooting thrives on getting very close to the subject to maximize the weird perspective.
Thanks,
barondla
Thank You. You have given much to think on and additional info to research. I didn’t think the 10-17 would fill the full frame sensor.
---------- Post added 01-04-20 at 12:26 PM ----------
Originally posted by Wasp Get the fisheye. It opens up new possibilities. This was taken with a Samyang 8mm f/2.8.
Thank You definitely the direction I’m leaning towards.
