Originally posted by odie91 To clarify, one hand shooting will be difficult only if I have the aperture block problem?
What I meant is, if your body (K-30 or K-50) has aperture block failure, you will have to use the aperture ring, like if it was a K-serie or M-serie lens. You can only use the lens in Av or M mode. In Av mode, metering is automatic but only work if you select the widest aperture (in DFA 50 case, it is F2.8). In M mode, you will have to push the green button to meter the light (this will close the aperture briefly to measure the light). So it's another button to press.
That said, on my K-S2 (and also K-30 and K-50 according to picture), the green button is next to the shutter button, so in fact I could use it with only one hand, just moving the finger between shutter button and green button. So in fact, disregard what I said about aperture block failure and single hand shooting, I should have looked more closely at pictures before writing.
Another distinct advantage of the DFA 50 Macro (compared to DFA 100 Macro for example, and most lenses) is the Focus Clamp. This will allow you to use Catch-In focus, something very useful. You select the focus (magnification), you press the shutter fully, and then you focus by moving closer or farther from your subject. The camera will take the picture when you will be exactly in focus.
