01-20-2020, 10:45 AM   #1
TerryL's Avatar
Tamron macro lens
Hello,
What’s that Tamron macro lens that’s supposed to be so good? Is it a 70mm, or 90mm?
Thank you
01-20-2020, 10:52 AM   #2
Seeker of Knowledge
aslyfox's Avatar
here are the reviews of tamron lenses
Tamron Lenses - Pentax Lens Review Database
and tamron adaptall lenses
Tamron Adaptall Lenses - Pentax Lens Review Database
you may be thinking of this one:
Tamron SP AF 90mm F2.8 Di Macro Lens Reviews - Tamron Lenses - Pentax Lens Review Database
I have no personal experience with that lens
I have a D FA 100mm F2.8 Macro ( not the WR version)
01-20-2020, 11:08 AM - 5 Likes   #3
luftfluss's Avatar
QuoteOriginally posted by TerryL Quote
Hello,
Thank you
Tamron did not produce a dedicated 70mm macro lens, however Sigma did so maybe that is what you are thinking of.
All of the Tamron 90's are excellent performers, as macro lenses tend to be.
I use theTamron Adaptall-2 SP 90mm f/2.5 (52BB) and find it to be wonderful.
01-20-2020, 11:11 AM   #4
Seeker of Knowledge
aslyfox's Avatar
if the OP wanted to take the time, I would advise looking at photos posted here to see what others have used for macro photography
*Macro* lens club - PentaxForums.com
01-20-2020, 11:30 AM   #5
amateur dirt farmer
pepperberry farm's Avatar
confirming the above, no 70mm for Tamron, but the Sigma 70mm macro is a stunner...
that being said, I have a copy of both the 52B and the 72B 90mm macros from Tamron's Adaptall line and both are amazing...
01-20-2020, 12:15 PM   #6
TerryL's Avatar
QuoteOriginally posted by pepperberry farm Quote
That must be it. I’m so glad you replied, because I knew you would know. Thank you.
---------- Post added 01-20-20 at 12:17 PM ----------
QuoteOriginally posted by aslyfox Quote
Oh my gosh, I’ve got the time. Thanks for the link.
---------- Post added 01-20-20 at 12:22 PM ----------
QuoteOriginally posted by luftfluss Quote
Wow! Yea, I think that’s the photographer as much as the lens. Amazing photos.
---------- Post added 01-20-20 at 12:26 PM ----------
I have the 100mm, too. I may go the manual focus route and get the Irix 150 mm.
---------- Post added 01-20-20 at 12:27 PM ----------
01-20-2020, 12:49 PM - 1 Like   #7
luftfluss's Avatar
Thank you. My "secret" is a I tote a small, lightweight resin stool around with me. That way I can sit, brace my elbows on my knees and make myself a tripod.
What disappoints me about the Irix 150 is the minimum working distance is 34cm - that's just 4cm further away than the Pentax 100 Macro.
01-20-2020, 12:53 PM   #8
amateur dirt farmer
[/COLOR]
you're welcome....
flickr albums for my macro lenses -
Tamron 52B:
Tamron Adaptall-2 SP 52B 90mm f2.5 Macro (M42) | Flickr
Tamron 72B:
Tamron Adaptall-2 SP 72B - 90mm f2.8 Macro | Flickr
Sigma 70mm EX DG:
Sigma 70mm f2.8 EX DG Macro | Flickr
and, newly arrived, the Irix 150mm Macro:
Irix 150mm f2.8 Macro (Dragonfly) | Flickr
01-20-2020, 02:15 PM - 1 Like   #9
Otis Memorial Pentaxian
Focus breathing...
Addendum: It's overall length relative to the Pentax is also a factor. BTW...MFD and working distance are two different things; MFD being measured to the focal plane. Working distance at 1:1 for the Pentax is 130mm* with the Irix dialing in at a little under 160mm** for a difference of only 3cm. By comparison, my Dine 105mm is 131mm.
* Per Pentax Forums detailed review
** 340mm MFD - (Overall length of 135mm + flange focal distance of 45.5mm)
01-20-2020, 02:28 PM - 1 Like   #10
amateur dirt farmer
Focus breathing...
and the weight difference is difficult to ignore....
01-20-2020, 04:00 PM - 1 Like   #11
Thagomizer's Avatar
Wow! great shots! I'm gonna hafta get my 52BB out more often.
01-20-2020, 04:06 PM   #12
TerryL's Avatar
Where does the minimum working distance come into play?
01-20-2020, 04:20 PM - 1 Like   #13
luftfluss's Avatar
When I am shooting macros, often I'm trying to get maximum magnification - as close to the subject (usually an insect) as the lens allows. With a 90mm or 100mm macro lens, this is usually around 30cm away from the camera sensor. For the legendary Pentax A* 200/4 Macro, the minimum working distance is nearly twice as far - 55cm! Having the minimum working distance being further away is useful because you are less likely to bother the insect, and also less likely to cast a shadow while shooting with the sun at your back.
Edit: as @stevebrot points out, I really should not be conflating "minimum working distance" with "minimum focus distance", but I'm afraid to change the terminology mid-discussion. The same principles apply to both, though. What it boils down to is with both the Pentax 100mm Macro and Irix 150mm Macro, you have to set yourself at a similar distance from your macro subject in order to get true 1:1 magnification. So, for my use, there is no improvement going from a 90 or 100mm macro to the Irix 150mm.
01-20-2020, 04:29 PM   #14
Seeker of Knowledge
aslyfox's Avatar
as mentioned it depends on your target if you are intending to get 1:1
animals/insects, it may be best to have a larger distance between you and your target
in a controlled environment, taking photos of stamps or coins for example, you may not need as much distance
. . . Pentax currently offers three autofocus macro lenses: the DA 35mm F2.8 Limited Macro, D FA 50mm F2.8 Macro, and D FA 100mm F2.8 Macro. Tamron also makes a 90mm F2.8 Macro. Note that the longer the focal length, the farther away you can be while maintaining life-size magnification. . . .
Read more at: The Advantages of a Dedicated Macro
Lens - Tutorial Videos | PentaxForums.com
01-20-2020, 06:55 PM   #15
At one time, I think Tamron used to make lenses for Pentax and the only difference was the Pentax super-multilayer coatings (optical formulas and mechanics were identical). That could well be the case for the Tamron 90mm. I have that lens and it is a fantastic lens. I've used it with the K-1 and it taxes the resolution of the K-1. Autofocusing is quick and accurate and I've used it clear down to 1:1 and it still performs. It gets a bit soft when stopped down to its limit which is not unexpected due to diffraction at those apertures but they do allow a greater depth of field. Great lens.
70mm, 90mm, adaptall, database, k-mount, lens, lenses, macro, pentax, pentax lens, photos, pm, post, review, reviews, sigma, slr lens, tamron, tamron macro, time
Wanted - Acquired: Tamron 90mm macro / Sigma 105 ex dg macro / Pentax 100mm macro pentakxian Sold Items 6 05-31-2013 09:58 AM
For Sale - Sold: Tamron SP AF 28-75 mm f/2.8 and Tamron 90 mm f/2.8 macro lens Vantage-Point Sold Items 5 03-22-2012 03:35 PM
Pentax 50mm Macro vs Tamron 90mm Macro catastrophe Pentax SLR Lens Discussion 13 09-20-2010 11:24 PM
Sigma 70mm Macro or Tamron 90mm Macro? Pentakun Pentax SLR Lens Discussion 19 08-01-2008 06:56 AM
For Sale - Sold: Tamron SP 90mm/2.8 macro (AF), Tamron SP 90mm/2.5 macro (MF) chemxaj Sold Items 11 06-19-2008 08:36 PM
All times are GMT -7. The time now is 06:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
